Went for a 3600, On a 3770k the now, Hope I done the right thing.
Don't worry, I guarantee you'll regret it*.
*For not doing it sooner.
*For not doing it sooner.![]()
Still cant decide to go for a 3700X now or hold on till next week at least to get a 3800X ….. got motherboard and most of the other bits. Wish I had taken the plunge on the 3800X when it was cheap on BF and Cyber Monday.
Intel are very slightly ahead for games (only just) but much more expensive than AMD. AMD is ahead for everything else and is much cheaper. It is also expected that new CPU's from AMD next year will probably come to the existing AM4 socket.I'm looking to upgrade from my i7 4790k, partly because the MB is getting slightly dodgy, but also because I would like the extra cores and threads of a modern processor for video compression. My current rig runs games at perfectly acceptable rates, so that's not an issue. Not sure if I want to go Intel or AMD. Last AMD I had was an Athlon 64, so my experiences in this regard are well out of date.
If it all boots up and works you won't regret it, the improvement I got from a 3770k in CPU heavy games was massive.I just bit the bullet and went for a 3800x (comming from a 4790K which was still great )
4790K to 3800x
16gb 2666 to 32gb 3600
570 motherboard
and keeping my Vega 56
all comming next week and i hope it will be worth it as all the advice came from here![]()
Having our it all together and played a lot of PUBG this afternoon/evening I'm really pleased with how much smoother it is. I've gone from 100% CPU usage in game to about 25%. I'm no longer CPU limited and my RX480 can perform to its best.I managed to collect all my bits this evening:
I went with the 3800X as the difference in cost over the lifetime of the CPU compared to the 3700X is likely to be irrelevant and there's a chance of a better bin for hopefully higher speeds.
- AMD 3800X
- Gigabyte X570 Aorus Elite
- 16Gb Crucial Ballistix
- Scythe Fuma 2
I'm hoping to put it all together and install Windows tomorrow evening. Hopefully I notice a massive difference compared to my venerable 2500K!
What're your load temps with the Noctua?I've now had almost a complete refresh. Today I put together:
* 3700x
* Gigabyte X570 Aorus Elite
* 32gb Crucial Ballistix Sport LT
* Noctua DH D15s
I already had a Radeon VII, almost new Seasonic 850w PSU and an unused Phanteks Enthoo Evolv case which I bought last year and stored away. The icing on the cake was the Alienware AW3420DW monitor which I also just got today. In the last few months I've also replace my desk with a beautiful white one and my chair with a Humanscale Freedom. In fact the only item I've not replaced recently is the keyboard which does now look old an chunky (an orginal Razer Blackwidow).
My old 3930k setup died almost three months ago so it's nice having a gaming system again.
Sorry for the slight delay. I'm currently in Linux and have just tried stressing it using the Linux stress tool. I set it to stress just the CPU and not other components. After 10 mins the peak it hit was 66.4 degrees. I'll be playing some games tonight under Windows so I'll check the temps after a gaming session and report back.What're your load temps with the Noctua?
you won't regret - I went from a 9900k to 3900x Love it.
It doesn't seem worth the cost of the swap.I was wondering weather to swap out my dual fan Alpenföhn Himalaya 2 but it's only 70c under load.
No it doesn’t. Thanks.It doesn't seem worth the cost of the swap.
