I know all about the Sony's that cost £1500-3000 or more at the time I had my PJ (all 1080p then) and have seen them in stores in special rooms but I feel your overrating them so that is my opinion and you have yours, you are not talking to someone who is clueless about them but there is a limit to how much I want to rearrange my home to suit a PJ instead of a TV (so sorry if you feel your are wasting you time).
I am not going down the PJ route again as since OLED came out it is not a must to try and get better blacks.
By the time you buy a high end PJ, screen and decorate you room to try get the best out oi it you could buy a bigger OLED, not sure how much 77" cost now but in a few years it will still be the same size but cost less same as 65" has dropepd.
I am sure I seen some TV's in the 80" range not sure if OLED but there is a 8k 88" LG OLED but cost £30K
When you started to say DLP is the best, you confused me.
77inch OLED is around £5000-6000. Hopefully when it comes to clearance stock, it comes down to £3,500.
I'm not denying the drawbacks of projection (cost, ergonomics, lack of ease of use, needs to be watched in the dark for the best PQ, wiring, lack of any HDR standard, no gsync). BIG difference between a 77 inch image and a 95 inch image and a 120 inch image (not even going to bring a 55'' or 65'' screen into the discussion).
But alas, it was just a suggestion. I myself did it and had little faith in it being any good (just a bit of a hobby) but I've been shocked by the £650 outlay. I'm now sitting with my 65'' TV (which now gets no use) and the PJ until the 77'' OLEDs come down in price
. I returned an LG OLED C9 55'', absolutely loved it as a monitor but it was too small for a TV.
Just did a quick video of the cheap sony PJ + the draper react 3 screen:
https://vimeo.com/380779097
(the bottom light grey bits are the screen.. haven't bothered to align it properly as i haven't decide dhow im setting this up).
and no.. im not stating those blacks are as good as oled.. but i think they are definitely approaching the mid-range end of my black level fetish considering its a big 95 inch projected image.
i did use the projector on a white wall and it was HORRIBLE.. like embrassing.
I'd like to once again re-iterate.. im not trying to make this a projector vs OLED. I'm VERY approreciative of the infinite contrast ratio and visual fidelity of OLEDs hence my plans to try and get a big one.
I'm hoping 77 inches strikes the perfect compromise in size. I'm sure it will tbh. Then I'll have to just chance the burn in as its hooked up to my PC.
