- 30 Mar 2010
- Exile
Hahaha! Jeez! Thats some upgrade as well!
I'll be expecting it to last until 2030
That looks very impressive, the ram colour sets it off perfectly.
@Jay85 looking sweet man, an dreal nice clear photos too!
Thanks! Its been a long month getting this together and finally to how i want it... never know i might change it up with a distro block next ha...
It's arrived! Looks a decent bit of kit.
Damn thats nice!! Sooo tempting to get one, can't wait to see you build this into your rig! Have you worked out your lines and routes now? Should be pretty straight forward with this with some 90 degree angled fittings and some extensions where needed.
I think this is right.
That looks about right i think, the good thing about these is you no longer need a reservoir/pump as the distro acts an all in one. Perfect solution!
Just a note, make sure you check all the screws on that distro block is tight before fitting it. I had a few bad experiences where EK had not tightened all the screws and caused a leak over time. Wasn't straight away so i thought all was okay.
Have you got a dead on side view of this? Just wanna see where the distro fittings are in relation to where your inlet and outlet ports are on your blocks.Ok so this is a rough guide to see how it should go.
I'm not totally happy with the CPU fittings, it's not the most elegant of solutions. It might be better if it's possible to go from the left CPU to top GPU?
That looks a lot better and cleaner. The straighter the lines the cleaner it will be. Have you started the build yet? Hope you managed to have some time this xmas to build it up.Ok I think I've created a better way of doing the CPU. It looks level to me.
The bottom radiator isn't screwed in yet, as once that's in I can't access the wires that need to go at the bottom.
How thick is your bottom rad btw?
Is it a tight right hand bend? Pics?Almost finished, just struggling with the tightest corner piece from the upper rad to the distro.
The rad is 38mm.
Thanks mate, tempted to try a 20.5 TX 360 at the bottom by shifting the vert mount up 1 slot. Need to do some measuring first though haha.
