- 20 Oct 2011
I had a reference Vega 64 for a while and repasting it with Kryonaut shaved a few degrees off. Undervolting it on top of that was the biggest deal though. Once I'd done that (which resulted in higher clocks than stock), it sat in the high 60s to low 70s with the default fan curve. Just try and pull the cooler straight up gently when you remove it, as the thermal pads are the stiff kind that's sort of like a putty and they rip and deform very easily. It's not a huge deal, but it saves some time reforming and fixing them. Also obviously be extremely careful cleaning the old thermal paste off if you have an unmoulded die.
Also, you can actually open the card up without breaking the warranty sticker if you want to. Take the backplate off, then remove the three screws in the tension brace that don't have a sticker. You can then simply turn the brace itself to unscrew the other screw (and the opposite when reassembling it). Leaves the sticker perfectly intact. Some board partners do use two though, so it won't work in that case obviously.
Wow, thank you for your reply, in particular the 3 screw trick with the bracket, I must admit the cards past owner appears to of been a smoker, I cleaned up the fan and removed a wealth of gunk, that brought the temps down a few degrees, I might just try and take the top off the card and clean the fan fully, is that possible?
