- 29 Feb 2012
- London
Is there a good starter guide online?
That would be about right, I only installed last night and was going have a fiddle about on it today.Whole game is buggy today.
great to see 9 people on discord today...
There isn’t one really if you’re playing solo, especially if people are setup in there. If there’s a couple of you then you can use grenades to distract and push multiple entrances.
If I’m playing solo I either go in through the front or the 2nd story using the stairs closest to the car extract. Most people hold top corridor and aim down it. I also like to go into 2 storey and try and snipe one or two, which then causes confusion and allows you to push. Most players panic when others move a lot and apply aggression.
If there’s a group of players sat in there then the reality is it’s a death trap/lottery trying to push them, it’s all just very confined.
What time was this???? In the ocuk channel?
Just started this, am learning customs as the biggest killer is me staggering around trying to find extraction points. Got a decent map from the web but so far playing as a scav and and once as a player have not made the exit once! Will have to join discord at some point but at the moment my experience can be summed up by 'Is this the extraction point? Bang!'
What are the labcards worth?
