The Elder Scrolls V: Skyrim - MODS & TWEAKS
25 May 2013
Kent.
I made my first few mods for Skyrim earlier, already has fairly good reception :) Feels good!
Added a Bear to Riverwood, and added some trees around Whiterun's river.
@scubes
Get yourself "Mod Organizer" for Skyrim SE.
Unofficial Skyrim Special Edition Patch
https://www.nexusmods.com/skyrimspecialedition/mods/266
Skyrim 2017 Textures
https://www.nexusmods.com/skyrimspecialedition/mods/2347
Static Mesh Improvement Mod (SMIM)
https://www.nexusmods.com/skyrimspecialedition/mods/659
Skyrim Flora Overhaul
https://www.nexusmods.com/skyrimspecialedition/mods/2154
Realistic Water Two
https://www.nexusmods.com/skyrimspecialedition/mods/2182
Alternate Start (No more horse and carriage start)
https://www.nexusmods.com/skyrimspecialedition/mods/272
25 May 2013
Kent.
@scubes My current mod list using Mod Organizer for Skyrim Special Edition.
Ignore the unmanaged mods, those are my own. Just the ones with the tick box, if you click "Plugins" then "sort" on the right hand side, it will automatically put the mods in the correct priority. I can load in safely and travel with this mod list. LOOT reports nothing major and they have been cleaned with SSEEdit.
https://i.imgur.com/qVvacKW.png
Man of Honour
13 Oct 2006
im having problems with my skyrim the problem is when im running my character swims on the path and the screen will go a light brown and the sound crackles any suggestions .
regards scubes.
Are you getting your hands/weapons going invisible intermittently when that happens? something like that used to happen if you were rendering too high FPS.
25 May 2013
Kent.
16 Aug 2009
I've pushed a few small mods out recently, learning as I go so they are quite small.
Not against the rules to advertise/post my own mods right?
Nope lol. It can be worth it if your work is popular you need to opt in to receive donation points you receive one per download each is worth $0.001 so 1000 downloads = $1 US. There are game keys to purchase in the Nexus store or pay for Premium etc. I've enough DP for Lifetime Premium.
27 Mar 2004
Between Realities
Player Home
https://www.nexusmods.com/skyrimspecialedition/mods/31419
Sleeping Giant Inn Reworked
https://www.nexusmods.com/skyrimspecialedition/mods/31337
Whiterun River Trees
https://www.nexusmods.com/skyrimspecialedition/mods/31252
Riverwood Bear (my first lol)
https://www.nexusmods.com/skyrimspecialedition/mods/31234
Don't happen to have a guide you used for get started? I'm just wanting to create some simple ones. Just simple things like a Power linked to animation\attack. For instance a new shield bash via the shout key.
I'd consider myself advanced in Skyrim modding. I use Zedit, SSEdit, converting to ESL, Bash patching\Smash Patching, etc, etc.
But actually creating from scratch, that's not something I've ventured into just yet.
28 Oct 2011
For those new to modding SKYRIM i'd suggest using Vortex, far less faffage than the alternatives like Mod Organizer and to coin a phrase 'It just works'. :D
Excellent free piece of software that syncs really well with Nexus and i've had far fewer issues than any other method, the UI is nice and all you have to do is D/L, install and enable.
16 Aug 2009
Darkfox127's video tutorials are probably the most comprehensive modding tuts out there. Written ones its hard to recommend any specific other than the ones on Bethesda's CK wiki pages. If you're looking to answers to specific questions Nexus' Creation Kit and Modders subforum is the most active out there currently, there are two though for each version of the game so check both though the SSE one tends to be more specific to that game as Bethesda has added new content there.
