Caporegime
- 18 Oct 2002
nV are pretty embedded now, would take a near Intel type collapse to see AMD take a lot of market share from them!
That is a bit unfair....... IF I was buying a new card today I would in theory have no problem going AMD. In practice however if i was weighing up between a 2070s and AMD I could save, £50-£75 and go for a 5700XT or I could get a card which has better ray tracing support and tensor cores (for what they are worth)......But here's the thing, AMD did at one point have the better cards at the top end. Yet customers still went out and bought the inferior Nvidia cards. Radeon has a branding/image/mind share problem and it's not going away unless they change their strategy.
Check out the stats over on Steam for Nvidia's SUPER cards, they've been outselling Radeon cards across the board. Even though similar performance Radeon cards can be picked up for less money.
AMD only have themselves to blame and they need to sort it out.
Personally, i don't care who makes the card. I just want to buy a 300/400 GBP card in the next couple of years without the feeling i'm being ripped off.
For me i would STILL go NV
For me i would STILL go NV, but it isnt because I have a love of men in leather coats.
As an aside - I dont know as i dont use it at home) but my colleague tells me he wont go back to AMD until they sort out their linux support..... He reckons the AMD drivers are utter trash.
this is 3rd hand info however so if you guys say he is wrong I aint gonna argue.
Exactly, they need a disruptive card at similar or better performance for 30% or more less in price! If the rumoured 5900XT comes in at more than £650-£700 for better than 2080tiAMD has to do way more than save 70 bucks for less performance and no RT to gain marketshare.
performance I won't bite. I need a compelling offer not similar performance ever so slightly cheaper.
That a turn around as historically Nvidia had better OpenGL and Linux drivers.
£700 is only slightly cheaper than £1200 for a potentially faster card?
I seriously just want an upgrade path for my
Vega 64 without having to buy NVIDIA.
You can get a RTX 2080 Ti for £950, not £1200. And that's an increase in price - they used to be £850 or so.
RTX2080Ti is 2 year old card also, soon to be replaced...............
A 2080TI beating Radeon will not be $700 you can be sure of that, It will be cheaper but not by $500, Nvidia set the pricing because the majority buy nVidia, not AMD, at the high end, AMD just go with it because undercutting Nvidia by huge amounts doesn't work, people just buy Nvidia anyway.
If it would be $700, cool, faster by a significant margin compared to 2080ti (at least 50%), drivers are ok from the start and has RT, then yes, people will be buy it.
If it's a bit cheaper, has RT (perhaps "meh" drivers), and is somewhat faster (20-30%), but with similar power consumption or greater, of course people will not make queues (and I guess this is where will actually be). Same goes with the other cards.
Traditionally AMD managed to shot themselves in the foot with one thing or another, even when they had good products.
