- 17 Aug 2003
- Woburn Sand Dunes
Repeated wireless charging isnt great on the battery. I'd avoid using it as the primary means of charging
I thought that the wireless charging was limited to 10w, but it looks like it may in fact be 12w which isn't far off the 15w max charge for the S10e from an adapter: https://www.androidcentral.com/samsung-fast-wireless-charging-20
Repeated wireless charging isnt great on the battery. I'd avoid using it as the primary means of charging![]()
It generates more heat, more heat is bad for the battery. If you are going to rely on wireless charging, turn fast charging off at least. I knackered the battery on my s8.What gives you that idea?
No, it's a fact that wireless charging generates more heat for any given wattage. What exactly dont you understand?Right so anecdotal based on your own experience?
I just ask because I have the exact opposite personal experience.
Anecdotal then? Gotcha. Heat kills batteries. Avoid it. Its pretty simple![]()
Wireless charging generates more heat. More heat puts more wear on the battery. These are both fact. Rather than argue the toss with me, go look it up before you decide I'm already wrong about it.
Anyway, its solid advice. Take it or leave it.
I'd rather you stop trolling tbh.
I make a living in part out of this sector, I'm stopping short of saying what you're saying is nonsense.. but it's nonsense.
DebatableSo yeah, I know what I'm talking about
Yes because that is at all comparable to the heat a fast wireless charger can generate through a coil that more often than not sits directly on top of the battery. Yup.and you may as well say don't put your phone in your pocket because it'll be warmer.
What else is nonsense then? That the input coils dont sit on top of the battery cells? I'm all ears - if you have something tangible to argue then please do so. You're making yourself look silly with all this avoidance.
I couldn't care less if you think I look silly, I'm not avoiding anything.
Indeed that's not a bad price, I wonder what the turnaround time on that is? I'm assuming you'd have to send it to a repair centre rather than having them do it in shop whilst you wait?
On a device that people use for several hours per day, why not ignore the "most efficient" charging method (whatever that is) and do what's convenient? If you end up with a bad battery, change it for 59 quid after 18 months if you intend keeping the phone.
You avoided every question i asked you. You keep trying to tell me I'm talking nonsense but wont tell which part of what i said was nonsense. That's Avoidance and I'm bored of you now.
