What have you done to your car today?
22 Sep 2011
Staffordshire Somewhere
Bedford, Combe, Goodwood need it for. It’s 105db static thats the problem. Stock exhaust.
Same as Oulton Park then.
If it's stock exhaust I very much doubt you would need it. Have you been on a track day before?
My car reads at 86DBa static with a de-cat and full 3" resonated system. On track it easily passes noise even with a screamer pipe. I know Bedford can be a bit funny but you should be able to drive all day there with no problems using stock exhaust. Just take it with you just in case and see what the noise read out says, you will be surprised. They don't immediately kick you off the track after going over the noise, they will pull you over and ask you to rectify it, then you can stick the baffle on if need be.
29 Jul 2004
Somerset
Just going on other owners reports. I think I’ll be ok at Bedford but only just, wont make Combe which is my local track and would like to go again.
Not done any days in the 4C yet, but did 2 in the Z4 which was indeed quiet iirc 87db static.
Caporegime
21 Jun 2006
Did the headlights on the Corolla, they are massive.
Done this a few times on diff cars and still a nice thing to see them come up so well after the work. You also realise how much light was missing before when driving. Tried the 3M kit this time and was impressed.
Also went to replace mid-pipe to rear silencer gasket as it was blowing only to find my rear silencer has rusted / split at the seam. Will give it a go at brazing tomorrow.
Otherwise it's looking like a trip for a T sport breaker for a stock rear silencer as they are getting rare now.
did you seal them afterwards with UV sealant?
233
233
21 Nov 2004
Wishaw
Broke it
hit a pothole rather painfully
double puncture possible damage to 2 wheels and the rear suspension has dropped on the drivers side
this is going to be both expensive and painful
233
233
21 Nov 2004
Wishaw
the offending pothole,
right way up this time, back to the workshop by 6 :(
currently shopping for wheels/tyres suspension and new fillings
1 Jun 2014
Holy crepe that's a big old pothole, hopefully you'll have some luck getting money back from the Council but it seems a lottery as to whether they'll pay out regardless of whether it meets the stipulations of when they will!
233
233
21 Nov 2004
Wishaw
only bonus is some of my other pics clearly show it marked up for repair faded paint suggests the council has known about it for a while i'd guess.
233
233
21 Nov 2004
Wishaw
went back this morning and managed to get some pics with a coffee cup completely in the pothole :D:D
pictures dont really give an idea of just how deep it is
10 Sep 2009
Today I finished the job that a Honda main dealer technician failed to complete this morning! It was in for a warranty repair on the rear seat folding mechanism, which they replaced without issue. But the technician left the seat trim hanging off the seat frame, so I was there outside the dealership putting it back together myself. I didn't have time to go in and tell them, and then wait for them to complete it. It's a minor thing but a bit "half a job" isn't it.
