- 1 May 2013
- M28
where do u add this? I tried to add it by right clicking chrome -> shortcut -> then adding it to the end but it doesnt work..
target reads as: "E:\Program Files (x86)\Google\Chrome\Application\chrome.exe" -enable-features=OverlayScrollbar
Isn't it two dashes at the start? --enab.....
Only works on fresh tabs. If you have tabs auto open from the last season it won't apply to them unless you close and reopen them.
It does work as using on both Chrome and Edge chromium.
I'll try a restart.
