- 20 Aug 2019
They're not externally IP rated and the IR output is extremely poor (10m) so I wouldn't recommend deploying them in the situation you describe unless you can tuck them right up under the eaves and you install the IR booster ring. Installing them with Protect is just plug and play. you adopt them like any other Unifi device and they get configured from the Protect controller. Its a great system. Just stupifyingly expensive compared to the equivalent from Dahua or Hikvision.
Ah bugger. Looks like I won’t be using them then. Soon as they arrived I’ll be listing them and shifting pronto.
