Oh! Reinstall your operating system!Are you sure I've just downloaded v15 about 15 mins ago.
The cable test doesnt work for me just sits there spinning circle left it for good 10 minutes.
Kidding
Try a different USB port?Oh! Reinstall your operating system!Are you sure I've just downloaded v15 about 15 mins ago.
Try a different USB port?I had a similar thing on one of tests... and moving the lead to a neighbouring USB socket kicked it into action. I wouldn't put too much importance into it.Yeah but link works with the one its plugged into so why not the test ?
Using a link cable or virtual desk?Told myself I would wait a few weeks before getting Alyx…… I got it tonight and just lost 2 hours to it.
I guess I am not bothered by VR much as I went straight in for free movement and it was absolutely fine, my only concern is that not taking more time with Super Hot and Robo Recall I will have spoilt them by going straight for Half Life Alyx.
Everything looks pretty damn sharp to me, so would be impressed if the main PCVR sets are even sharper with a bigger FOV, might get one from the next generation.
Do me a favour and try just the 2m Anker cable with the Device>page 2 "Test Cable" feature will you, and let me know what the Gbps value is?I was using a link cable, a 3m Ugreen extension and 2m Anker cable, seems to be working great, its my first go at PCVR and everything was straight forward to setup, no cable issues, no driver problems.
Thanks for that!Finally v15 installed for me today so did the test, I got the same result with all cables:
I have 3 USB ports and a USB C on the top front section of my desktop and it didn't matter whether I used those or directly into the motherboard in the back the results were the same, so far I am playing Alyx and Robo Recall using link and have had no dropouts / disconnects.
- 2m Anker USB A to C = 1.8Gbps
- Above with the 3m Ugreen extension = 1.8Gbps
- 2m CBUS USB C to C = 1.8Gbps
My setup is an Alienware Aurora R8
i7 9700K
11GB 2080 Ti
32GB DDR4
Thanks for that!
It's interesting how people are reporting the visuals over Virtual Desktop as at least as good as a link cable, if not better. And no real negative performance either, so starting to wonder if a link cable is even worth it![]()
You can set Github to email you whenever a new release is published just make sure you are signed in and click on the 'eye' icon and choose releases only.The new 1.11.x beta Virtual Desktop update has improved it no end. Lots of little nice touches have been introduced and it runs a lot better than 1.10. More seamless interaction with SteamVR and Oculus Desktop, before sometimes you had to give it a manual kick but now its just so automated. The included menu of your Steam/Oculus games within the Quest display now is a massive plus.
Geez just checked and 1.12.1 is out now with a load more improvements this guy does not stand still !
https://github.com/guygodin/VirtualDesktop/releases
i7 9700K
11GB 2080 Ti
32GB DDR4
Approximately how much data does the Link software actually send through?
