Yep Thingiverse is messed up again![]()
If you can do 3d modeling, then design with a hole to push the rod into, what type of plastic are you printing with?
PLA will be rubbish outside, you need to find one more hard wearing
Yes, was just looking at this, anyone else getting involved?
..Added a BL Touch, a 1.15 board and a glass plate to my ener 3 pro. Took a while to get the z-offset dialed in, and for some reason it didn't like to print on my glass panel. Gone back to the magnetic sheet that came with it, and the prints are fanatastic.
Must have been something wrong with the extruder settings, or a plug not in correctly, as it was only extruding 40mm when I did the 100mm test. EVen after sorting that it was not printing properly. Used the latest version of Marlin 2.0.x.x, sorted out the BL Touch settings, and it was extruding bang on. Really strange, might have been a setting int he other firmware that I had messed up.
Thnking about buying the extension kit for the ender 3, or even making my own, which would be cheaper. Allow for bigger prints on the X and Y.
Maybe I should have just bought a bigger printer..
Did you follow any particular guide? My glass bed arrived today. I have SKR mini, BLTouch and BMG dual gear extruder on route too.
I'm going to fit 1 by 1 and test so I dont have to troubleshoot a million things at once.
Funny thing is, my glass plate was way better than the mag plate that came with it, before I installed the BL Touch. Levelled the bed so many times, changed temps, cleaned it multiple times. Only thing I havent done is sort out the fade. The problem with the extrusion was the filament setting within the menus, for some reason when it is set to 1.75 it screws up the extrusion, I got a strange measurement of 2.35 for my e-steps. Turned that off, and my recalculated esteps was 101.Glass bed takes a little getting used to, but as this point all I have to do is make sure its clean.
For PLA I bumped the bed temp 10-15 degrees compared to the textured build plate. PETG is a little more tricky and ended up bumping bed temps up about 25c to 85c. The occasional trouble some print needs a brim rather than a skirt
So I have just bought an FLSUN QQ S pro delta its my first printer need something that didnt take up loads of desk space and build volume wise is more than big enough for what i want to do. Does anyone have any experience with this model of printer or deltas in particular. l have already decided my first print is going to be a modification to the printer itself as apparently the stock fan cooling vents arent angled enough to be effective so going to print off a couple that direct it closer nozzle.
