- 18 May 2010
- London
You guys using Ryzen Balanced or Ryzen High Performance power plan?
What power plan are you all using, Ryzen Balanced?
New chipset drivers yo!
Revision Number
2.04.04.111
File Size
50 MB
Release Date
4/7/2020
Release notes.
Same issue.Well... there is a bug somewhere.
Firstly I couldn't remove the old version. When I ran uninstaller it was just sitting at 0%
I installed new over the top. Then did an uninstall. To find that the driver still showed in add/remove as still installed.
Right click remove and it is gone. Installed the new version which is 100% installed but doesn't show up in add/remove programs....
Same issue.
Revision Number
2.04.04.111
File Size
50 MB
Release Date
4/7/2020
Release notes.
One thing. People on reddit report higher performance scores on CB even for the 3600 with these.
Had a BSOD this morning from cold boot.
No memory dmp or mini dump.
Everything seems OK. So will see if it happens tomorrow and hopefully catch what it said on screen.
Nothing at all tbh. Offset - 0.1 on voltage from day 1, with stock memory primary timings, but tightened secondaries. Unchanged for a couple of weeks.Anything in event viewer?
What components do you have overclocked is the next obvious question?
