Are the stands part of the actual speaker, @Zeebedy?
Yes matea they are..
https://www.overclockers.co.uk/raze...kers-for-pc-rz05-02450100-r3w1-sp-04d-ra.html
Setup my Razer Nommo speakers. Great quality for the price, they really are!
Damn! What size is that, 30"... It looks bigger.
Cheers. They certainly look the part!
Nicked the idea from a few on here, with the Ikea Top, Drawers and legs. Totally new build, with new monitor, speakers, keyboard, etc. Only thing i kept was the mouse, hah.
Also nicked the idea. Great solid top but went for the cupboard instead of the draws. Also done some cable management on the underside with some work still to do. Planning a new build with either triple 27'' screens or a single ultrawide.
Very cool, nice setup. Loving the cable management. Neat.
So clean
I need to get on the cable management. I've got cables everywhere.
Very nice set up!
I am looking at doing the same and still debating how I will hide some of the cables etc.
How are you sticking the power gangs to the underside of the worktop? Are you using velcro sticky pads or tape?
Used velcro sticky tape cut down into pieces. they seem to be holding well.
My advise is to take your time and star with the main wires, power cable,display cables and leave the thinner mouse keyboard etc last.
Tip: Try to avoid running any audio or speaker wires against other cables, especially mains - this will reduce noise and mains hum.
Anyone here used Ikea Capita legs on their DIY desks (or any other project for that matter!!)? If so, can you tell me what type of material the black stuff is on the bottom of the straight legs? I'm guessing some kind of plastic?
Also, if you've used the angled Capita legs, what height are they? The website says 17cm, but I don't know if that includes the bottom bolt or not!
Nice one, thanks!I have the straight capita legs on my monitor shelf. I can't lift it up to double check the underneath, but stabbing the side of the black bit with my nail says its just a hard black plastic, not rubber or squidgy or anything like that.
