That’s good news thank youNope - I ranked up a lot before buying the full game and didn't lose any ranks.
Call of Duty Warzone adds 2FA requirement to combat PC cheaters
https://www.videogameschronicle.com...e-adds-2fa-requirement-to-combat-pc-cheaters/
Said it was getting worse......
That’s what i was thinking. Or just their IP somehow so they can never play it againUntil you get banned then have to buy it again!
I've finally done it! I'll be glad to never have to touch some of those guns again and now I can just play as normal! Success!
Depends what res and if you are limiting fps. 3440x1440 i limit to 90fps for 100hz gsync. On 1080ti i went from 70-90fps most of the time with ray tracing off to 20 - 60fps with ray tracing on.
So as said, off and very much so.
If you’re at 1080p and limit to 60fps it might not have any hit at all
What gun & mods is that?
Something definitely needs to happen though. Surprised there is no anti-cheat in place!
1440p monitor is 165hz so capped FR to 165fps
It's the Striker SMG. Can't remember the exact attachments but I used the stock and rear grip that reduce ADS time, monolithic suppressor, tac-laser and the tactical grip
Nice, this was what i was using before changing over to the Uzi
Then no, no way could a 1080ti run with ray tracing enabled at 165fps. Im surprised if it can hold 165fps all the time with ray tracing off
On my 1080ti with ray tracing off I would get dips to 40-50fps sometimes. But then 3440 x 1440 requires 1.34x as much grunt to push 4.95MP over 3.69MP
I guess someone could do the math as im rubbish at it
It does, i gave it another go and got a 10 kill streak!I’ve only just stopped using the holopoint rounds - it shreds people either way in HC. Love it!
I would just try it with and without. Start the campagne, watch fps at a static point right at the start then turn it on.Yeah I'll keep it off!
Went from Striker45 to SKS then to the Uzi
Never tried those, i started on the m4a1, then to AK47, Striker, SKS, Uzi.I'm a big fan of the M4 with the SOCOM rounds. 1 hit kills and super mobile, give it a go in semi-automatic!
Dammit, back to the m4![]()
