It was a discounted preorder price.Anyone noticed the price has risen? At least the C14 stuff. Glad I bought when I did.
But what about the other settings?The official settings is the XMP.
Just downloaded 1.70 and comparing to 1.73 I see no difference in timings with manually imported 8 pack 3200/14 at 3600 or 3800 so not sure where your seeking this. The 14 14 15 14 28 is just the non imported V1 settings on both versions though it's called A3/A2/B2 on the later version instead of V1.Base timings are:
1.7.3:
14 15 15 15 30
1.7.0:
14 14 15 14 28
tfaw is also less
1.7.3 is no good in my opinion. It spits out slow timings.
Here they are side by side:
1.7.3 timings and score:
1.7.0 timings and score:
Using 1.7.3 and importing XMP I got 14,14,14,14,28 timings so I'm not sure why I'm getting different from opethdisciple. Edit: I see it now, 3200 kit vs 3600 kit.
So I've done a full CMOS clear by removing the battery and without changing any memory settings in the BIOS so it's running at 2400 I've had one fast boot from cold so that's progress although I don't want to run my 3600 RAM at 2400. The next boot from cold I had 4 seconds of the loud GPU period. From there I've enabled DOCP to get the memory running at XMP speed and the next cold boot wasn't fast but not the slowest but I'll see how it goes with the next few power cycles.
Asus Prime X470-pro and latest BIOS. R5 3600. I need to put this stuff in my sig.What motherboard and CPU do you have?
Were the other settings left on auto?Just running memtest on the 3200/14 kit @3800 14 15 16 15 30, needed 1.47 to boot and 1.49 to stop throwing errors, so far so good 20 minutes in but still a long way to go.
The other timings are from the A3/A2/B2 timings from the latest dram calc as they are a bit tighter than what I was getting from importing.Were the other settings left on auto?
Thanks, good to knowThe other timings are from the A3/A2/B2 timings from the latest dram calc as they are a bit tighter than what I was getting from importing.
I've noticed that no one has posted better scores with the ripped stuff than shac or myself...
