RNG gods are smiling on you I had 2 events with no mask or any rewards whatsoever earlier!
I now have 2 Father Winter helmets. Do you want one?
Yes please I can swap you any you do not have I have several of most of the others now! Including the Deathclaw one.I now have 2 Father Winter helmets. Do you want one?
Ok thanks for the kind offer. I will grind a bit more but getting fed up with it now as too many griefers either nuking the event & or trying to wreck it once it starts as they obviously did not get a decent RNGesus LOL!Turns out father winter helmet can't be dropped.I just tried to drop it for you at Helvetia.
Can't trade it either. I just tried that. Won't let me offer it.
EDIT: I noticed that when I tried to drop it I got the standard "This can't be dropped, it will be destroyed but you know the plan to make another one. Do you want to continue?" message. A quick look online confirms that it's not actually possible to make one, that the option is always greyed out.
So it seems that the Father Winter helmet is treated internally as a normal helmet with a paintjob on it and the paintjob is set to have requirements that are hidden and are impossible to meet. A bit of a slapdash way to implement it and it makes trading it impossible. It also makes it quite easy to accidentally destroy it. Not the best implementation, but very Bethesda.
Gauss Minigun is really good DMG wise but the big issue is ammo you need Fluxes & lots of them which makes me not bother for now to get the PlansI just reached Ally with the raiders...but I realised a few days ago that gauss miniguns are wildly impractical due to ammo usage and the fact that you only craft 27 bullets a time. 10 hours of grinding for 2 minutes of firing. Normal miniguns are unsupportable as it is and they have 180 per crafting.
OK, first Fasnacht griefer. FalloutFist killed all the robots with grenades. Which shouldn't be possible, but is.
Secret Service Armour Plan is excellent though but around 7000 Gold for the complete set & almost PA level DMG resistance.
T65 is still the best Plans to get first as the DMG resistance is really good it hardly ever needs repairing. In fact after almost a month mine is still in more or less the same condition! But 6900 for the plans + 750 for the cal shocks + 2000 for the jetpack so its some grind then you need 10 fluxes to craft the jetpack & another 5 for the cal shocks!
Up to Ally with Raiders weeks ago & over halfway towards that with Foundation now. PSA check the different vendors in Crater & Foundation as you progress rep wise you unlock new weapon plans some are caps only purchases you need a lot of caps for that with both factions!
yep if you cancel the event in quest log then you can kill the bots. I've not had it happen yet but only taken part maybe 15 times on the lvl 30~ gunslinger char
The main annoyance is the Sloth quick kills. Getting a tag on the sloth is really handy for a lower level char for legendaries and scrip. It's happened the last 4 runs, probably as the high levels are just getting bored and burnt out from multiple days or running it every hour
Did RR a few weeks ago with a very high level heavily armed team of about 10 players & its not worth the effort for the rewards & no matter what it keeps throwing all those tough enemies at you constantly for the entire duration of the eventOff on a tangent...radiation rumble gets on my ****. It's a rock hard event with no better rewards than far easier events, so few people do it. I usually teleport in when it starts, wait for a couple of minutes and teleport out again when nobody turns up to do it. I could solo it solely to slaughter glowing ferals in the hope of getting a few legendaries, but I'd feel bad about the NPCs dying because I roleplay in games.
Not sure if it beats BOS but do you get random 3* LEG effects when you craft each SS piece as it uses 1 LEG module you have to buy from the Purveyor. SS just seems really good to me so far I am now working on all the pieces buts its going to take me another 5 weeks to get enough GoldDoes it beat BoS combat armour? The posts I've seen from people who have both says it doesn't, but I haven't bothered checking. A lot of people don't know how much better BoS combat armour is when compared to normal combat armour. It adds a lot to DR and ER.
so hopefully by then Season 1 is released
2PM today they take offline to hotfix the vending machine issues & server maintenance. So expect it back online around 4-5PM GMT. When the vending machines are back I have a lot of items to add back into my shops! and will also pop by yours @Angilion perhaps see if you can add the Winter helmet mask to your shop for me if your around same time as me please.
https://bethesda.net/community/topic/412791/upcoming-fallout-76-maintenance-june-2-2020?language[]=en
Waste of resource playing it for no special rewards IMO![]()
