Have you tested performance as you go or are you just chasing numbers?
During our testing we found that gaming performance actually dropped when the memory was pushed north of 3600MHz. AMD later admitted that above 3600Mhz-3733Mhz (depending on CPU quality) a divider is enabled on the infinity fabric and this can negatively affect performance for most applications. The reason for this divider is to enable the CPU to cope with REALLY high memory clock speeds for application specific solutions (i.e. professional systems). You'd have to push memory speeds to about around 4600MHz to get back to the same level of gaming performance.
Generally, the best performance results are gained from 3600MHz with really low latency settings.
If you are building a gaming PC I'd definitely suggest that you go back to 3600MHz and run some benchmarks each time you adjust a setting.
I'm testing as I go. FCLK at 1900, MEMCLK and UCLK at 3800 right now. When you guys were testing, did you try 3600 MEMCLK with higher FCLK speeds?
)! Just a few more pieces of the build left to arrive tomorrow
Previous order last week (AIO cooler and PSU) didn't
