 - 18 May 2010
 - London
The biggest gains on Ryzen is memory.
FCLK + (ram speed + latencies)
Hmm
I ran Cinebench R20 yesterday (pbo off) and saw no such gains.
Depends what you're doing. Even gaming isn't that simple, as some games prefer low latency and others perform better with high FCLK/UCLK/MEMCLK even with worse latency. I'm very happy at 3600 CL16. I know that some games would be happier at 3600 CL14 but given it won't even boot if I disable Gear Down Mode, that's never going to happen with my DIMMs.The biggest gains on Ryzen is memory.
Yeah, when I say FPS I generally mean the lows because that's all that matters once you hit around 80-90 FPS average. Regarding GDM, what I meant was that GDM requires an even CL, so the "next bump" after CL16 GDM on is CL16 GDM off, which my setup doesn't like. Therefore I'll have no chance at CL15 or CL14.
I'm not chasing every last inch of performance, so would 3600 CL16 and 3200 CL14 be much of muchness when paired with a 3600 chip?
Only looking at 16gb
Cheers! Now I know what to look out for in MMEither of those would do well.
Thing I've realised anyway is the ram you buy needs to be tweaked anyway as just running the ram at XMP is not really getting out of it half of what it's capable.
Even the 8 Pack 3600 CL14 sticks need to be heavily tweaked. Put them in at their default configuration and they aren't no where near as fast as they are capable.
there were hints that next generation will hit 2000 fclk, so maybe a 4000 capable kit would be more future proof.Well I'm guessing then if I want to vaguely future-proof (say dropping a 4x00 in the board in a few years time) it would be better getting 3600 RAM?
I know it's all up in the air
