- 21 Dec 2019
- Planet Thanet
Usually the extra 4 or 8 pin is for extreme overclockersHi guys quick question as I’m building this right now... the mobo cpu_pwr placement has an 8 (called cpu_pwr1) and a separate 4 pin header (called cpu_pwr2) do I need to use this second power header or ignore it? Build Hardware is as above.
thanks!
If not using liquid nitrogen or helium it's not normally needed
Fromt panel power light illuminates but when I hit it nothing happens! Help!
