Caporegime
- 11 Mar 2005
- Leafy Cheshire
Either 16GB or 32GB for my 9x builds![]()
Thanks, will get something ordered, currently testing on a 1gb card!
I will check it out although I am also skeptical about unofficial service packs. I tend to keep my installs as vanilla as possible. Dont really like phils dos pack as helpful as it is...@LewisRaz Perhaps consider using nlite to slipstream the unofficial SP4 pack for XP. That's what I did and it saves me a lot of hassle when doing a new install. Contains every update released post-SP3, plus .net runtimes.
https://ryanvm.net/forum/viewtopic.php?p=133918
Normally I wouldn't recommend unofficial service packs (don't really rate the ones for Win98, Autopatcher whilst being selective over updates is better IMO), but this worked well for me.
Ball IntelliMouse turned up today, sitting on my original Func 1030 mouse mat!
So @Firestar_3x, I've found my S3 Virge/DX and am tempted to do a build with (at least one) Voodoo II 12MB alongside my Socket 7 board (the one that currently houses the P233MMX), but the Virge currently only has the 4MB onboard and nothing populated in the 4 expansion sockets. Does yours have the expansion memory, and if so is it the same spec as the onboard memory? I'm tempted to order some but it'll be different brand and likely a different ns rating due to availability.
Two sound icons on your task bar, you heathen!?Also 3D tested the 9800GT finally. It seems fine, passed a run on 3DMark2003 with flying colours.
Mine didnt but there was a fairly easy mod to allow it.Don't think i can run the K6-2 in my Socket 7 board, unfortunately no 2.2v option for the core, lowest i can go is 2.8.
Looks like i'll be sticking the 233mmx in, should still be a good upgrade from the PR200 currently in it.
Does anyone have a good source for old ATI drivers? I have installed the XP SP4 but still having bother.
What card?
Guru3d still has the driver section up, remember them having some good modded drivers for all types of cards: https://www.guru3d.com/files-categories/videocard-drivers.html
