@krooton
Patriot Viper 4400 kits can also be tuned to run at 3600 cL14 with fast timings.
I would expect most high frequency Samsung B die may be capable of similar.
Happy I bought the 4400 kits now with the rumours of 2000 fclks.
Surely ram speed will have less of an impact with Ryzen 4000 because the latency issue will be fixed by having an 8 core CCX.
I agree with this. If your GONNA buy now (with no info) then I'd probably go with these high frequency sticks.
At the moment with ram, people looking to buy right now are in limbo. You either buy ram which is a good fit for the 3000 series or you don't buy at all and see how the 4000 series functions when they do land.
Planning to buy a set of ram and then thinking your gonna overclock it when the 4000 series drops, is probably gonna be fine. But we just don't know what speeds are gonna be achievable so how can you buy based on information we don't have.
This is what I'm thinking. Invest more now into a 4000Mhz set so it will be good for 4000 series or go for a semi budget 3200mhz set and save some money.
Anyone felt the need to use one of these brackets which supposedly positions the waterblock better to where the chiplets are inside the ihs?
. I'm seeing a constant 6c to 7c lower temps when running anything that involves all cores maxed out. Idle temps seem to stays about the same though.
People spend a lot more than that changing cpu coolers in the hope of temp reductions.
You upgrading to Zen 3 Shac? I guess it’s the only way you will beat my score in the cinebench thread without upping the volts?@krooton
Wouldn't be worth it for me, as already get low temps, idles around 32/33, loads around 43/44![]()
What cooler / case are you using?
Corsair H100i RGB Platinum, with the fans set to quiet, and the pump balanced, case is the Phanteks Evolv X.
EDIT: Found a pic :-
