What’s the chipset fan noise like? Asking for a friend.
Mine comes on very briefly at POST, haven't had it come on in Windows at all yet.
Interesting...
Thanks.
Never had the need to come on rarely?Mine has never had the need to come on rarely, but very minimal when it does!
Soit does come on, but rarely and doesn't make much noise whe it does? Can you still notice it though (above all your other fans)??
Haha I was a half asleep typing that. It doesn't come on often. If I'm playing cod warzone it will but I certainly can't notice it. I don't know why people get so hung up on chipset fans.
I guess it's because some can be (more so in the pasy) very high-pitched and whiney, and I assume that if you have a silent system with only low frequency hums from larger fans then you will notice the whiney chipset one more more. Happy to hear it's not a problem for you though!Haha I was a half asleep typing that. It doesn't come on often. If I'm playing cod warzone it will but I certainly can't notice it. I don't know why people get so hung up on chipset fans.
I guess it's because some can be (more so in the pasy) very high-pitched and whiney, and I assume that if you have a silent system with only low frequency hums from larger fans then you will notice the whiney chipset one more more. Happy to hear it's not a problem for you though!![]()
You could solve that issue with a well placed 120mm fan and unplugging your chipset fan.Thanks for the info. I’m interested cos my current board is doing my nut with fan noise (see separate thread).
Has anyone tried memory overclocking with this board?
I've got Micron rev E. to play around with (and only a few more parts required before I can build my new rig)
Surely it would be easier to play an inverse waveform of the noise the fan emits thus nullifying the soundYou could solve that issue with a well placed 120mm fan and unplugging your chipset fan.
(sure I watched a tomorrows world about this back in the day)Awesome!!!Yeah, these are my current results with the tomahawk, it's awesome!!
current is 3800 cl 14 Fclk 1900
What's the CPU clock now?Yeah, these are my current results with the tomahawk, it's awesome!!
saved 2 is XMP 3600 cl 16 Fclk 1800
saved 1 is manual 3600 cl 14
I meant the minimum core clock frequency, it wasn't clear to me from your post if you've overclocked it or not.What do you mean sorry? My multipler is auto at PBO so 3.6 then up to 4.2 automatically.
If you don't mind me asking, can you tell me what voltages (SoC, DRAM etc) you're using at those clocks?@MSIUK Support
Hi there,
no worries here you go:
Only an option for disabling LAN. Thanks for the swift reply, love the board!
Good morning! We've just received news from our BIOS team....
