Iiyama GB3466WQSU-B1 Curve (1500R) 34” 1440 144Hz VA panel FreeSync Premium Pro
8 Mar 2005
Hi all,
In the market for a curved ultra wide. My budget is a max £600 and I need Freesync as I have an AMD RX5700 (Gigabyte Gaming OC).
Does anyone have any news on this forthcoming Iiyama monitor and when it will be available in the UK? (and will OcUK stock it?). Reading on Reddit I understand it will be out in Europe in June and be about the same price as the flat panel (~£400 or thereabouts).
What do we think of this panel?
Cheers, D.
23 Sep 2014
North West
I believe it will be the same panel as all new 34" UW 144Hz 1500R VA
Xiaomi https://www.displayspecifications.com/en/model/259c1bb0
AOC https://www.displayspecifications.com/en/model/5e071c5b
Lenovo https://www.displayspecifications.com/en/model/b4d61efd
Nixeus https://www.displayspecifications.com/en/model/b2de1c36
So I guess you can check reviews for them and see if you like it. General panel performance should be the same across them all, only difference will be design, connections, and the stand.
OP
8 Mar 2005
Hi @Infiniteey that is really useful, thank you for the reply and sharing :)
If somewhere in the UK can stock the Iiyama GB3466WQSU-B1 Curve (1500R) for approx £400 I think it will do very well.
Buying an ultrawide with a max budget of £600 seems to be a challenge, so many compromises to consider :rolleyes:
30 Jul 2012
Iiyama have released the specs of the Iiyama GB3466WQSU-B1 Curve (1500R) on their website for those that are interested: https://iiyama.com/gl_en/products/g-master-gb3466wqsu-b1/
Waiting to hear back from OcUK if they will be stocking it @NikTheSHNIK.
To compare to the FLAT Iiyama, see: https://iiyama.com/gl_en/products/g-master-gb3461wqsu-b1/
Decisions decisions...
Thought you were talking about another one, seems good, ultra wide though. Found it at 429.99.
OP
8 Mar 2005
Yes have seen that as well - thanks. Would rather buy from OcUK (assuming they will stock it). Since @Infiniteey's post, I have looked at all the other monitors that use the same curved VA panel and been comparing them to the Flat IPS Iiyama (with the non-UW Dell you got as the backup plan!). Stock availability might become the deciding factor I suspect.
21 May 2018
South Wales
Which Dell are you talking about? Interested in this Liyama.
21 May 2018
South Wales
@Mr G the Dell I mention is the Dell S3220DGF, checkout https://forums.overclockers.co.uk/threads/dell-s3220dgf.18885642/ for discussion. @random_matt has just got this display. It is good and it is a VA panel (It is a personal choice between VA vs. IPS).
For me personally, I want to get a curved screen, and hence going to a 32 or 34UW for a budget of £400, this will mean a VA panel.
Ah thanks. Interested in the S3220DGF and the Iiyama. Depends how quick OcUK can stock this model and prices.
10 Oct 2012
Denmark
I've had the Dell S3220DGF myself, the monitor looks stunning, overall response times for a VA is good. The dealbreaker for me was still the undesired black smearing. That said, for a VA it seemed to do better than most VA would in this regard. If you aren't overly fussed about it like I am, the S3220DGF is a good screen, just watch out for freesync/adaptive sync flicker.
21 May 2018
South Wales
I have this flicker with my MSI MAG272QC and it's annoying but only does this with certain games?
10 Oct 2012
Denmark
VA panels in general seem to suffer more from it than IPS screens. My Iiyama IPS ultrawide would also have some very slight flicker but only perceptible to me on load screen and very faint. What the actual cause is I have no idea.
21 May 2018
South Wales
Not sure if this is correct but it's the low framerate under freesync range apparently, don't quote me as it's something I read recently.
10 Oct 2012
Denmark
Yeah that part i knew about, but why though? I've read someone claiming it's a difference in voltage causing the brightness to be different depending on the hz. But is this a scaler issue or is it a GPU/driver issue?
21 May 2018
South Wales
I think driver related... this is far to common with other VA monitors from what I can gather from reviews and user feedback, brightness flickering on both GeForce and Radeon cards.
