No at the moment it's still available - I'm going to start charging you lot for Overtime...has the last black case sold?
So I've read that some motherboards can't connect to the front usb c?
Also a reviewer said you can't really see much through the tempered glass? That's a shame as I would wann see my components.
The glass panel is the only downside for me.
I'd much prefer another mesh panel to match the rest.
It'll run cooler, and personally think it would look better.
You can only see the riser cable, edge of ram, and top internal panel over the PSU anyway.
I've got a custom ventilated front panel pre-ordered which should arrive sometime in July. I pulled out of the NZXT H1 though because I'm still in two minds between it and the Mcase. So I may have a ventilated custom panel for the H1 and no H1 in a months time lol
If it's a 4 pin then you can control it via the Asus fan ultility and set a curve. I usually set a flat curve to about 62c, then it ramps up. Also see if there is a setting to smooth out fan speed changes.
AI Suite is fine, I've had no issues with it. You can probably do it in the BIOS as well if you wanted to avoid using the util.
If it's 3 pin, I think you'll want to change the fan.
It's 3 pin
I could use NZXT's CAM software
I don't think that will work. With a NZXT AIO the fans would attach to special connectors coming from the pump, and that would go via USB giving control via CAM.
Grab a better 4-pin fan optimised for static pressure and you'll be set. Noctua NF-A14 is a good fan https://www.overclockers.co.uk/noctua-nf-a14-pwm-chromax-premium-grade-fan-140mm-fg-06l-nc.html
