Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Mint.
If you condense it down to what it should have been though, using actual advisories I've seen used before...
Monitor and repair if necessary (advisories):
- Nearside Front Anti-roll bar pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
- Offside Front Anti-roll bar pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
- General underbody corrosion
- Nearside Front brake caliper binding but not excessively (1.2.7 (f))
- Nearside Rear Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
- Offside Rear Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
Apprentice probably did it.![]()
Check the MOT history of mine
YD60 AZN
