- 14 Jul 2005
- Birmingham
ou can always try the automapper thats out, forget what its called its not brilliant but you upload your song, it works out the map then gives you the map files to incorporate into BS.
Beat sage. It doesn't get great feedback but i'll try it and see if it works for a map I started to work on.
