Can you find out what firmware version you are on?
As pretty sure mine looks better with +2 and no overshooting too.
I want one, i wish somewhere had stock right now![]()
Nice one Phix, glad you finally got lucky with the monitor lottery!
Still thoroughly enjoying mine too, just need a next gen GPU to arrive now as 3440x1440 is quite demanding for my vega 56, at least for wanting the 100+ FPS![]()
Yeah, definitely want this monitor again (but a none broken one)
Ordered a 32" curved VA panel to replace it which arrived today....is worse in every way...it also arrived with dirt under the panel so that's going back also. This was ordered at another site mind.
The VA colours were garbage in comparison to the IPS i've been using for the past 6 or so years. The curve also felt really odd...almost felt nauseous from it lol.
Not going to risk a B grade monitor. :/
Guess I'll wait for the next lot of stock to come in, which I believe is end of july? Reckon there is any chance it could have some of the issues resolved by then? perhaps a newer firmware batch?
Hi, is that the curved version of this monitor? The Iiyama GB3466WQSU?
I'm tempted to get one of these. My current monitor is an Acer Predator XB271HU (27", 1440p 165HzG-Sync). My partner has an Asus MX34VQ (34", 1440p UW, 100Hz G-Sync) and I find that her screen is not as good to game on as mine. I don't know if it's down to the 100Hz or the VA panel, t just feels flat and a bit smeary. Would people recommend this as an upgrade? I love the real estate that the 1440p UW resolution gives you. The other monitor I was eyeing up was the Predator X34P which is similar to this Iiyama?
Should I order this or wait for the curved version? I'll be using it mostly for productivity.
It's a fantastic monitor if they can just fix the QC, I'd happily take a replacement if they had any in stock
Yeah same...I think
What are you using now?
