- 5 Aug 2017
- Cornwall
Looking very good for the stock cooler! You might want to give the HBM is little push. I use 1140MHz, my brother runs 1130MHz. So 1100MHz+ shouldn't be an issue. Should give a couple of extra fps in some games that can make use of the extra bandwidth.Wow, been reading through this thread slowly, and I actually discovered something called the washer mod, took the card and installed 4 of these that I had laying around in my nuts and bolts tin, they are 0.6mm thick: https://imgur.com/bJkp5iG
shaved another 8oC of the junction temps, I was waiting through the benchmark for it to go above 90oC, it never did, so quickly took a screenshot towards the end: https://imgur.com/ZLyzJCp
WOW, that will do I think: https://www.3dmark.com/3dm/47548119
