MSI B550M Mortar, EVGA GTX670 FTW.What mb and gpu?
I'm mostly concerned that I can't access the BIOS at all. I don't see any splash screen or anything until I get that message and that's it.
Does pressing f1 or f2 when that message pops up do anything?
If it has bios flashback try updating to the new beta bios. 1.0.0.2
If that doesn't work you might be best contacting MSI customer service directly as it would likely be faster than going through the rep on here.
Do we have an MSI rep on here.
Built my new pc up but I can't get into the BIOS.
It gives me a "there is no gop support detected in this card" message.
But I can't access the BIOS to do anything about.
Ask the staff in the customer service section.Anyone heard if Overclockers are going to stock the B550m Aorus Pro as they only have the Elite model on pre-order at moment.
No good I don't have another pc to do any of that.Sounds like the GPU doesn't support UEFI.
Look for a BIOS update for your Graphics Card, and flash it if you can find a newer one, to locate the BIOS version use GPU-Z.
Check for your card here... https://www.techpowerup.com/vgabios/?manufacturer=EVGA&model=GTX+670
If you can't find it send EVGA support a support ticket with your S/N and card version and they will send you a compatible BIOS.
I find it annoying that the board doesn't just boot into legacy mode.Local friendly person or shop can do it. Just get the file from EVGA first, or spend £xxx on a new GPU.
Even worse that it didn't allow access to the bios.
I thought you could access the BIOS no matter what.
I actually want a new GPU, the gtx670 I imagine isn't going to be up to much in newer games especially now I have a 1440p 165hz monitor.Can't access without a working/supported GPU, and no iGPU. Borrow a GPU from someone?
Can you lend me your Tardis I want to buy up a load of B450 boards.Let me just grab my TARDIS
Anyone that gets an MSI board don't install Dragon Center.
Took me ages to figure out but it was limiting my upload speed to 5Mb/s with a process called cFosspeed.
I have no idea what the idea of that is but it's stupid.
