system isDepends on your motherboard I suppose. But you will likely in the cpu section see something like 36x, you need to adjust that. Trouble is, if you can’t even find that, you should probably not be messing with it, or take it easy and go step by step so try 40, then 41 etc.
AMD RYZEN 3600
Be Quiet! Dark Rock Pro 4 CPU Air Tower Cooler.
MOTHERBOARD...B450 TOMAHAWK MAX
GPU radeon rx 590 gaming 8gb
corsair lpx RAM.. DD4 2X8 16 GB 3200MHZ
psu corsair rm750x
would love to be able to overclock the 3600.
