New AMD Build Approx £2,000 budget help please!
26 May 2018
Bewdley, UK
Hi All,
This is a bit of a reboot of an old thread here:
https://forums.overclockers.co.uk/threads/new-build-approx-2000-budget-amd.18862742/
I now have the funds at last, so looking to build something over the next couple of weeks hopefully, I understand now isn't the perfect timing to be building due to new hardware / part shortages but would like other people's ideas on what might be a good starting point. If I could get something to play on now and have to upgrade the GPU in a year or two that fine by me.
Budget includes tower and monitor only (have everything else mouse keyboard etc).
£2000 I was thinking 3700X, B550 / X570, RTX 2070S GPU. Nice 1440p 144 MHz monitor.
Size wise due to size of desk space I was thinking Micro ATX might be more suitable.
What are others people's opinions? help and assistance greatly appreciated! :)
Here's what I said last time for games etc (they haven't changed) :D:
Hi All,
I have been reading this forum for awhile now and trying to take as much of the advice on board as possible.
It has now come to a point where I can think about building my own rig after watching lots of build videos etc.
Budget I'm thinking approximately about £2000 ish all in (less cost would be nice!) need monitor, keyboard mouse etc as starting from scratch just don't need windows.
This will hopefully replace my PS4 and need to get another console (PS5 etc when released). Would like it to last a good few years with minor upgrading along the way.
Games I play vary quite a bit from Football Manager, GTA and FPS, open world games also really want to get Cyberpunk 2077 when its released.
I'm also leaning towards AMD CPU due to costs but will consider anything suggested.
Screen wise due to space I'd probably limit it to 27"
Thank you in advance for your assistance!
30 Jul 2007
Lincolnshire
Seems decent the new Kolink Citadel, but not keen on the chunky front mesh panel and RGB looks a bit much :p
If you want a sleek and premium mATX case, the Lian-Li Lancool 205M is very tidy. Just not in stock with OcUK atm :( It is in stock elsewhere though...
Also to revise my spec suggestion, I'd swap the PSU to this NZXT C650 650w that's just had a few land in stock by looks of it today.
OP
26 May 2018
Bewdley, UK
If you want a sleek and premium mATX case, the Lain-Li Lancool 205M is very tidy. Just not in stock with OcUK atm :( It is in stock elsewhere though...
haha yeah you might be right on the rgb the lancool 205m looks tasty. :cool:
Thanks for different PSU. :D
Another thing I'm stuck on is a cooler, any suggestions?
30 Jul 2007
Lincolnshire
Depends on what's left in the budget and what you're looking for, some great air and water coolers out there these days.
Very powerful and quiet the Noctua NH-U12A air cooler
https://www.overclockers.co.uk/noctua-nh-u12a-high-performance-cpu-cooler-120mm-hs-03k-nc.html
Great all rounder and low temps
https://www.overclockers.co.uk/scythe-mugen-5-black-rgb-cpu-cooler-120mm-hs-04j-sy.html
Cheap and cheerful (it's actually very good for the money)
https://www.overclockers.co.uk/arct...duo-white-cpu-cooler-2-x-120mm-hs-074-ar.html
Or if after an AIO water cooler, then one of the Arctic Cooling AIO will do great (obv depends on case you pick as to what case/radiator you can fit)
https://www.overclockers.co.uk/air-...e-watercooling?ckSuppliers=46&ckTab=0&sSort=2
Or if you go higher end AIO water coolers then NZXT and Corsair all do great coolers (again, depends on what case you get as to which model/radiator will fit)
https://www.overclockers.co.uk/air-...-watercooling?ckSuppliers=431&ckTab=0&sSort=2
OP
26 May 2018
Bewdley, UK
Still undecided case wise how's this looking?
Changed cooler.
Also switched the mobo as wanted one with wifi, sorry wasn't in the spec. :D
I did look the artic freezer the only thing that put me off was the 2 year warranty. How does that compare to the Cosair H100i RGB Pro?
My basket at Overclockers UK:
Total: £1,406.58 (includes shipping: £11.70)
30 Jul 2007
Lincolnshire
Looks good, the decent thing about the case I guess is the dual rad support.
You could get the 240 or 280mm AIO if you wanted and fit it at the top (unless you just want the RGB air cooler :p)
OP
26 May 2018
Bewdley, UK
OP
26 May 2018
Bewdley, UK
Caporegime
21 Jun 2006
Anyone else have any opinions? getting close to ordering finally. :D
you could save a lot of money - yet have absolutely no noticeable difference in games by going
3600X - that will last you 5 years easy. plenty of power and cores.
instead of an AIO - which won't last more than 5 years get a cheap air cooler which will run quiet and cool.
https://www.overclockers.co.uk/alpe...ion-dual-fan-cpu-cooler-140-mm-hs-05h-al.html
that is what I would buy.
try and get a platinum power supply and you don't need 650W. 550W should be fine. in fact 450W should be fine but I'd go 550W anyway or thereabouts.
motherboard b450 tomahawk is around £100 - the saving can be put towards your next cpu and mobo upgrade in 5 years time.
i'd also try and save on the monitor if possible. there are loads of options and i find monitors are really expensive especially g sync.
OP
26 May 2018
Bewdley, UK
Thanks for that you make sure great points, this is why I'm glad I asked you guys for help. :) I've had a look and thought about it and think Air makes more sense especially for me as a first time builder.
I originally had the b450 mortar max spec'd so might go back to that.
I'm thinking a freesync monitor that's compatible with g sync or do they not work as well?
Will have a look what PSU's are in stock, looks like some are returning now.
Man of Honour
26 May 2012
they're fine and if it's gsync certified then are guaranteed to work fine
but even non-certified gsync monitors that are freesync work fine 99% of the times. i wouldn't worry
OP
26 May 2018
Bewdley, UK
Thanks :) I was originally thinking about the LG 27GL850-B quoted above but now the price has shot back up not sure what to look at.
Any other suggestions? not sure what would suit the games I want to play. I don't want something that won't be good for FPS for example as may get into those at some point. Don't want to narrow my options before I've started. :D
