***The Official Guitar Thread***
Not been to the store, but I did buy a bass off them online. Arrived in the bare Fender box, clearly nobody thought double boxing it was a good idea. Opened it up to find a massive dent and crack in the back of the instrument where something had clearly whacked the packaging. Returned and ended up buying elsewhere, mainly due to them having no more stock rather than a lack of faith but still.
Not sure I would trust couriers shipping a guitar and amp - gonna make the trip to them as I want to hear/touch/feel it before buying.
So, got some work done on the Harley Benton kit this week, fortunately the weather round here was absolutely ideal for painting on Sunday too (humidity dropped right down to sub-60%).
So, first off the body. Reasonably well finished with a few machining marks but well sealed, just gave it a run over with some 600 grit before any paint to tidy up the marks. The ground wire hole is a very rough job, but that will all be hidden under the bridge plate. 3 piece body, looks and feels like basswood to me.
Had to fill in the drilled pickguard holes as they were a mile out from the included pickguard, and even more so from the replacement I'm going to be using. So, toothpicks and wood glue to the rescue! Cut back and sanded flush before paint.
Pickguard fitted - nowhere to drill for one screw above the controls, debating just leaving it off as it makes no difference or gluing a bit of scrap wood to the cavity to drill into. Will figure this out later down the line.
Headstock, shaped! Going to an early 60s colour scheme but wanted to strink the headstock a bit. The body is very lightweight so trying to avoid any neck dive issues. As such, used a template for an American Deluxe size headstock rather than a vintage sizing.
Primer!
And colour coat, Shell Pink nitrocellulose. Used a full fin of both colour and clear coat and it's looking good with a decent shine to it. Now to leave it for 3 or so weeks to fully cure before wet sanding and buffing.
Still got work to do on the neck, need to get a decal made up and give the whole neck a quick dusting of clear, with more coats to the headstock front. Going to leave the back a satin finish like the modern Fenders as I love the feel of my Player Jazz.
Whereas I got a Kramer from them back in March which came double boxed.
I'm rather impressed, I bought the Desert Flame Burst Its more a brown burst that red and the neck is dark. Sound great and feels nice.
I'll post a few pics later.
can you post a side view like this? I want to see what kind of neck angle it has.
I've got to say I've been buying and playing classic guitars for 50 years but that looks awesome, I'd love a blind test with it.
About 10 years ago my mate invited me up to his to blind test 3 guitars and the one I picked out was an Ace Frehley Gibson Les Paul £200 Chinese copy while the other two were £1500+.
It played, sounded and looked excellent.
Going down to Brighton for a couple of days in a couple of weeks. I emailed GAK to ask if i can demo a couple of guitars. Both of them are out of stock, but the guy asked me he could order them in but it would be 10% deposit on each guitar. One is £999 and the other is £1300.
Damn that is an expensive price to pay to try out a guitar!!!
I'm trying my damnedest not to entertain a Martin SC-13E; as much as I adore my GS mini Koa; my fingers keep falling over themselves!
?? How does that work? You get the deposit back after you’ve tried them and decide you don’t like either?
Gear4Music do a 30 day no quibble return policy...need to pay for it obviously but u have 30 days to try it at home...obv need to be careful, don’t wear tops with zoos etc to avoid scratching
you can even pay a bit more (think it’s ~5%) then you get 180 days to return!
that’s a nice looking guitar @Mr.E.
Morning Chaps,
I was saving for the Cort x manson guitar but alas i've replaced my bathroom so budget has all but vanished! I have had a look online and whats available at the really low end of the market. There's a few that have caught my eye:
Jackson Js22 - this is £200ish but has a whammy bar which i don't think i'll get use off. https://www.andertons.co.uk/guitar-...2-dinky-in-metallic-blue-w-amaranth-fretboard
Schecter C-6 / c6 deluxe / plus about 250-300
Jackson JS32 without the whammy bar
Not expecting any of them to be great but they all seem to get alright reviews. The kinda of style guitar i want.
I was looking at guitars like those Schecter and Jackson ones, in the end I got a Chapman ML1 modern for a sale price. It's a bit different, has a nice finish, is nice to hold etc.
Ah that's the one people keep losing their minds over on Facebook...
How is the jamming functionality? Wondering if its better than the Trio+ but everyone who demos it online seems to just focus on the different tones/effects and how the amp sounds
I’ve not tried it yet, only got it at lunch time, no customs! But first impression it’s well built.
Just had a quick go before dinner. Brilliant. It’s like a THR but better. I love the app integration and intuitive of it. Turning on pedals is easy, changing amp too is easy. If you don’t want you can just turn the amp selection knob on the Spark and that also changes the amp in the app too!
i also had a quick go on the backing track, works brilliantly. Set tempo, play a bit and it’ll generate something for you.
I have spent about the same money on Marshall Acton and this makes that look over price. Sounds great as a Bluetooth speaker too.
It's the app integration that elevates it. I'm a terrible guitar player so the ease to jam to a beat with chord prompts, I know will help me. I'll have a proper play tomorrow
