NR200 Owner's Thread
See this post:
https://forums.overclockers.co.uk/t...00-new-itx-case.18889817/page-9#post-33781554
Assuming that still holds, stock should arrive at OCUK this week. Hopefully that means some of us will get cases this week, though it could be next week depending on the day that stock arrives.
I ordered mine two weeks ago. Before ordering I asked when the case was going to be in and would I be in first shipment and was told yes and it was expecting the first week of August. So hopefully this week or early next week?
Is the safety margin for the TG panel roughly the same number of mm over the official number? Appreciate the need for a safety margin, but it would be useful to know whether it's worth ordering certain coolers to test, or a complete waste of time and money. I don't mind testing stuff that might fit. I'd rather not test ones that definitely won't.
The exact distance in our test setup is 155mm from the CPU heatspreader to the actual TG. But I have to remind you that I cannot officially say the clearance is this. Officially I have to account for a safety margin.
EYUsLYw
If 140mm would fit, I'd assume they would have been a standard option in the case itself. Nonetheless, if they do fit, that would be even better! With a converter bracket from 120 to 140 you may get height issues to the GPU though.
It can physically fit below the motherboard since the area is open, but there are no holes for mounting (the existing hole pattern is for 120mm and 92mm). A 3d printed adapter could do the trick. Of course mind the graphics card thickness.
XGzOUFC
XGzOUFC
Thanks for the confirmation. Appreciated
Thanks. That's all any good be could hope for. Time will tell as to what coolers fit and what don't. But at least it's worth testing, for example, Fuma 2 in this case with TG.
@cmxiao @Ron_CM
Hi,
I'll be using a 2.5 slot Vega 56 Pulse initially in standard orientation which is a 2.5 slot GPU, do you know what width fans will fit in the base please? The slimmest I've found available are 13mm. If you're not sure do you know the distance in mm from the base to the bottom of the first PCIE slot?
Thanks
