- 21 Jul 2005
- Officially least sunny location -Ronskistats
He was talking about FS2020, 30%![]()
Does it do DLSS?
Does it do DLSS?
Rumor is the XBox Series X does.Does it do DLSS?
Nvidia seems to be making some real fighting talk there - usually they tend to be relatively quiet.
DirectML iirc.
It appears memory is a real problem for Ampere:
https://www.igorslab.de/en/nvidia-a...elf-the-board-partners-are-still-in-the-dark/
It's consuming a ton of power and is clocked to the very edge! I wonder if Micron screwed up??
Micron = space invaders beware !
On topic - does anyone know if Ampere will be capable of connecting at 4k, fully 10-bit (no chroma sub-sampling), HDR and 120Hz over HDMI 2.1?
Does anyone know if the 3090 will support SLI?
I’m planning to buy 2 3090s...
one on 7nm and one on a much older chip and node 12nmlol... well he's already a lair, the 5700XT uses the same power as a 2070 Super, they are the same performance....
unlikely
NVIDIA CEO: Our GPUs are Twice as Efficient as AMD’s Regardless of the Process Node
Samsung are better tho...
That's the thing, games are getting very good at faking lighting and will get better again with UE5 etc.
