That's huge!
||And can make other things
https://www.google.com/search?q=nvi...clbCgBw&bih=731&biw=1536#imgrc=tCdwvMtIsae_dM
That's huge!
Normal, when they don't implement a workaround like a 512-bit memory bus between the chip and memory modules.
This thing will need E-ATX motherboards and very large Full towers PC cases:
https://wccftech.com/nvidia-rtx-300...or-799-rtx-3070-for-599-and-rtx-3060-for-399/
Hm, might skip this gen if these price rumours are true, keep my b grade 2070 super for strategy games and buy an xbox x series.
Best time to buy a console is when they just come out as they will be a bit more competitive with pc gpus.
Then once the xbox gets slow/aged in a few years I will sell it and get whatever gpu is out then and go back to just the PC.
This plan largely depends on how much the new xbox will be though.
Card looks stupidly big, a triple slot cooler sounds like its gonna be a power hog.
I'm expecting a lot of higher-end aftermarket card to use 240mm AIOs for these.
If the 3090 is about 20% or so quicker than the 3080 then for sure the 3080 will be the best for the money, if those prices were accurate anywaySeems like 3080 is the reasonable purchase this generation.
It's not too bad, albeit awkward for air cooling the CPU I imagine. What I'm curious is, do the supposed prices have the 20/16GB variants in mind or will that be extra? And will the 3070 be = 2080 ti in performance. Hmmm.
7552 Shaders. vs 4,352 on the 2080TI, that's +73%, that should make it about ~50% faster than the 2080TI.
Also. TDP, 400 Watts, vs 250 Watts 2080TI.
Ok, lets says there is no "80 CU RDNA2" lets say its 64 CU, AMD have done 64 CU's many times before lets assume that's it.
5700XT = 40 CU @ 1900Mhz
Big Navi 64 CU's = +60%
The PS5 runs at 2.23Ghz: vs the 5700XT that's + 17%
Lets round Big Navi up to 2.3Ghz because if the PS5 can do 2.23Ghz i'm sure Big Navi can do at least 2.3Ghz.
The 2080TI is 30% faster than the 5700XT.
Big Navi +60% Shaders + 21% clocks = 5700XT + 81% at 0.7 Scaling = +57% actual.
So a 64 CU 2.3Ghz Big Navi would be about 30% faster than a 2080TI, GA102 would be 20% faster again.
This assuming 0 IPC gain RDNA2 vs RDNA1.
Which card is likely going to be best performance for the money? The 3080? Or have they likely now priced all the cards in a way that there's no price/performance sweet spot?
I mean the card that offers the best performance without spending a lot more for just a bit more performanceIf you literally mean performance per pound then probably the 2660 to replace the 1660?
Just saw the size of that card and price, lol if NVIDIA think I am paying £1500 for a card.
I am buying ps5 and keeping my 1080Ti, will wait till AMD is competitive. By the size of this thing you can tell NVIDIA was really worried about Big Navi. I assume AMD should be competitive next round. This rou d i doubt AMD can top that monster 3090.
no doubt about it 3090 is going it be crazy fast, if AMD can match the 3080 they are lucky.
almost £1500 for a gfx card lol.
That APU is about as quick as a 2080TI
