Right, cabling done
be careful of esdRight, cabling done, although missing fan splitter, will have to order one. Looks an absolute mess, however most will be hidden by the graphics card.
Another question. Can I run my 2070 Super on a single rail from the power supply? Would be good to be able to remove one of the cables.
Another question for you guys. My motherboard has 3 fan headers, one shown as CPU along with 2 further system fans. I have currently connected the Pump from the AIO into CPU fan header, is this correct? I intend on plugging the two fans on the rad into system fan 1 with the fans at the top of the case into system fan 2.
now i get it3 X PWM Splitter plug 1 PWM fan into the red sort of port that as 4 pins &
the 2 black ports have 3 pins that take the speed off the main PWM fan in the red port
this cable was for CPU fan PWM
in red port & the 2 x black ports for the 2 top case fans
Got mine running 2 x Arctic P12s fans for the bottom of case
