Its available at Richer Sounds now with a 6 year guarantee.
What is the best stand for this so I can get it as far back on my desk as possible?
There are a few on the jungle for around £20 just search for tv stand.
Ok thx. Any ones to avoid?
I'm considering avoiding a GPU purchase this gen again as I'm expecting another epic rip-off, and as a result will consider a console purchase instead. Is there anything to indicate one over the other in terms of HDR support and general compatibility with this screen?
I suppose what I'm asking is have any of you got your eye on a console to pair with this, and if so why that particular choice?
Yup most places have got it, if anyone wants it make sure to look for this model : OLED48CX5LC and try selfridges they do it the cheapest @ 1.4k but don't know about their warranty.
Curries model version has the 6 in it.
Sadly I have found out JL will not be stocking them till September+
Still, in 3 weeks we should have Sonys 48 oled also available, I am intrigued to see some A/B comparisons or reviews but probably won't happen for a while.
NothingHi whats the difference between your recommended model and Currys 6LB one
why is there 2 models numbers if isnt difference between them
That said, I can't resist getting a 3080ti, as long as it's 40-50% over the 2080ti performance. 4K 120Hz (with some settings lowered ofc) will set me up for years to come.
It’s the stand as far as I know. Dark silver on the Currys model and light silver on others like John LewisBezel colour or stand colour could be slightly different that is all. Everything else is the same.
