One important thing to consider looking to reviews I think ...
Remember the base clock of the 2080 series was largely ignored and most auto boosted into games around the 1900+ compared to the "stock" of 1710.
By the sounds of it the ampere chips are not as overclockable due maybe to the process in its infancy, or heat/power restraints.
In the interest of comparison, finding a reviewer that locks the core to stock clocks will benefit those looking at AIB worst case scenario![]()
good luck getting a response from superflower, customer engagement is zero.
AIBs are using normal 8/6 pin connectors.Still no idea what to do about my PSU and the connector if I buy an AIB. Super Flower Leadex Gold 650w. Is it worth emailing them to check?
They emailed me back about the PSU being enough for the GPU, but nothing regarding a connector. I'll pop a question over and fingers crossed.
Why are people calling it pre-orders when the cards are being released on Thursday? Pre-order happens when something hasn't released. These cards are releasing on Thursday at 2pm and that's when you can order, not pre-order. There is no pre-order here. OCUK have stated they have stock ready to send.
how much stock though that is the question..
You cannot place pre-orders yet but you can on the following dates:
- 3090 September 24th 2pm
- 3080 September 17th 2pm
- 3070 October
I have been pestering from the beginning waterblock suppliers.It would appear not. Jacob from EVGA said they have based that card on the reference board but changed a couple of things, Which annoyingly means a reference waterblock wont fit it., GRRRRRRRRRR
According to Ezmodding(they sell Bykski blocks), only EVGA with XC3 has confirm using reference PCB. Plus they do two distinctions between reference models. Type 1 with standard capacitors and type 2 with high capacitors quoting this brands for high capacitors:
- Zotac
- Galax / KFA²
- Colorful / Igame
- Palit
- Gainward
EKWB has in his config database a few more models, but they haven't specify which block is compatible.
You can check the models there:
https://www.ekwb.com/configurator/
In resume I wouldn't put the hand on the fire for anyone..
Thats annoying then that EVGA has slightly tweaked the board on their basic card. Was going to perhaps go EVGA and watercool it.
Looks like its the Zotac Trinity then for me.
So the Zotac is a bit of a beast. At 317mm, its going to be a bit too big for my Corsair 280x and front mounted radiator. Even with the radiator moved to the top it looks like it will encrouch onto the fans.
