- 17 Oct 2002
- Stoke-on-Trent
Wrong thread sorry.
Just be careful when cancelling the MS order. I've know many, MANY times that Amazon takes pre-orders, and then close to launch they send an email saying "delivery can't be guaranteed, now estimated 'another month'"
Have they revealed the price of these yet?
Stolen from another kind member.
Buy up to 3 years of Xbox Gold either UK or Brazil to get it even cheaper from cdkeys.
If using the Brazil codes, connect to a VPN with a server in Brazil and check your IP location shows you as being in that country.
Go to microsoft.com/redeem in an incognito window to avoid any saved logins, login to your MS account and redeem the live codes, do not accept the free month for renewing if you want to add 3 years as it will take you over the max 36 months.
Log out, turn VPN off and then either use the xbox app or website to use the £1 upgrade offer. If you have already had a game pass sub you can buy a 1 month Ultimate code from CD Keys for £8.99 and just add that on the xbox app. It will say you are buying 1 month of ultimate but if you check your subscriptions after it will be prepaid until however months of Gold you had.
It's only when you add Gold to an Ultimate sub that you get the rubbish conversion and existing customers with an expired gamepass sub can do the same thing but they might not have the £1 offer so just use a 1 month prepaid code instead.
was a disaster if you wanted access which is the way i was going sat in que online game then after 1 hour it wouldnt let you get past console choice.and smyths just didnt work full stop so just popped into smyths store and pre ordered x for 25 deposit
£159
Yeah I did say stolen from another member. Similar thread on ukhotdeals but you laid it out more clearly. Thanks bud, saved me £200.Oi thief!
It still works as far as I know, the brazil gold codes have got a bit more expensive though.
Have you literally done this method just now?Yeah I did say stolen from another member. Similar thread on ukhotdeals but you laid it out more clearly. Thanks bud, saved me £200.
I was worried it would end after I bought the console and I'd be paying £10.99 which is still a decent deal. This can't be beaten though and I have 2 years of gaming for the price of a single game pretty much.
For a 1TB SSD! Ai ai ai
Just looking on ebay and people are selling the series X for £550...whats the point? As won't the fees be about £50 or so? Seems like a waste of time.
then there's the risk of scammers robing you blind (karma laughs) - IMO not worth the risk unless you got dozens to sellyes it’s pointless at that sort of profit as at 10% cut you’re out, then there is the postage so easily another £10-£15 for decent postage considering the weight and cost.
Sweet, though I assume you cannot both play at once?Ha no worries, I just rewrote what others had done to make it clearer.
I've split mine with a mate so we have effectively paid just over a £1 each per month for ultimate![]()
