Maybe.
EVGA and ASUS look to be in the clear, but the other AIB's will be like 'bugger' how are we going to wiggle out of this one (probably with a VBIOS update that pins the top end boost under 2Ghz).
@malccy, nice summary.
I got my Gigabyte 3080 gaming yesterday and havnt had any crashes yet while playing with it. Just heard about this issue and seems this card has the worst setup of capacitors so hoping it doesnt cause issues. Will keep testing over the next few days to see if anything happens but so far so good.
Its pretty quiet considering the last windforce cooler i had was super loud, tops out around 67 degrees at 75% fan in my setup. Will push the OC a bit and see if it induces any crashes like mentioned.
Confirmed then? But due to the rush and Secrecy /NDAs some AIBs didn't get the memo.EVGA statement on the matter:
'Recently there has been some discussion about the EVGA GeForce RTX 3080 series.
During our mass production QC testing we discovered a full 6 POSCAPs solution cannot pass the real world applications testing. It took almost a week of R&D effort to find the cause and reduce the POSCAPs to 4 and add 20 MLCC caps prior to shipping production boards, this is why the EVGA GeForce RTX 3080 FTW3 series was delayed at launch. There were no 6 POSCAP production EVGA GeForce RTX 3080 FTW3 boards shipped.
But, due to the time crunch, some of the reviewers were sent a pre-production version with 6 POSCAP’s, we are working with those reviewers directly to replace their boards with production versions.
EVGA GeForce RTX 3080 XC3 series with 5 POSCAPs + 10 MLCC solution is matched with the XC3 spec without issues.
Also note that we have updated the product pictures at EVGA.com to reflect the production components that shipped to gamers and enthusiasts since day 1 of product launch.
Once you receive the card you can compare for yourself, EVGA stands behind its products!
Thanks
EVGA'
show me a product launch that doesn’t? Come on seriously for every one saying for Msi there zotac even the fe cards are doing the same. There are so many parts to the launch hardware and software alike. Can u name 1 product launch that doesn’t have horror stories?
I’m not defending anyone all I. Saying is there could be 100’s if not 1000’s of reasons for this come. There are plenty of people not having issues with the msi card on this forum
Are you joking? Or trolling or both?
Nvidias launches are generally brilliant, everyone knows this. AMD launches are bad, this launch is worse than anything AMD has done recently..
There is still time for AMD to drop the ball but i just cannot see their launch being worse than this
You can return the card in 14 days for a replacement/refund if your not happy so I fail to see the risk in all this.Can't take the risk after such a big spend, shame as was on the list and hoping but have a Gigabyte on order and so will cancel and see how this pans out before I re-order.
KentMan said:Nvidias launches are generally brilliant, everyone knows this.
Even if you do get a faulty card the good news is this is something that will be fixed quickly and any faulty cards replaced.
How are the cards faulty? They still run stable at the required base speed.
Worst case an updated driver is issued to change the OC function to run a bit slower - could be just 15Mhz clock slower.
Early adopters getting it in the XXXX again, glad I am not one of them
that might not be true though because how many FTW3 cards have been on sale and shippedEVGA FTW3 Ultra 3080 is the most expensive card and they didn't use MLCC so cant say much
so I don't think price is the issue here
My bet is there are a number of moving parts in all of this. If it was just capacitor choice all cards of that configuration would be affected. However, if it's a combination of that, GPU quality, cooling, boost behaviour etc. Only those cards unlucky enough to have a particular configuration will exhibit instability. Much harder to find the pattern though if it's more than one factor.
The biggest question for me is the obvious lack of QC before the cards went out. At this price point I'd expect more. It's not like they were shipping millions of cards to satisfy global demand and a few crept in, there's only a handful of people that even have a card.
