Pretty sure Gibbo quantified very small as less than 10 and small as 10 to 50What makes you think a small amount equates to approx 25?
Its just a nice middling sorta number
Again, if you read the statements thats not true. The only difference between non-OC and OC is the factory does the overclock for you. The binning is the same and the lottery's the same. A non-OC has the same chance of going to 480W as the OC.
Last word: It’s not a better-binned chip. Chips are binned before the AIBs get them. The cards are the same. The OC has a factory overclock. That’s it. Nothing else. I’m done here. If you all want to believe it’s something more then that is up to you.![]()
100's of one particular.. I doubt, at the moment.
100's in a mix and match of all brands and variants, at low quantity, that's possible..
Gibbo. He has defined it more than once
very small = less than 10
small = 10 to 50
reasonable = 50 - 100
good = 100+
I should be about 200 or so I think, but no. I am number 854 in the queue MAYBE. That is if I am in the queue. What a joke. OC clearly don't want me as a customer.
Sorry,wrong thread,its a 3080. Sorry guys. will repost in right thread.800+ for a 3090?
The BIOS is the same. The VRM is the same. The power delivery is the same. Every component is the same, so I think the closest you will see to evidence at this stage is making an assumption on that basis. It would not be logical for ASUS to lower the power limit on a card designed from the ground up for overclocking, especially since the cards are identical from a hardware perspective.Got a link to something that the none oc goes to 480W? The only mention I have seen is on here.
Even if they did, you could just tweak it back up again because same card, same BIOS. Draw your own conclusions.
Both versions of the card recommend an 850w PSU, too.
Yeah, it’s gonna be the same BIOS but the boost clock setting will have been set differently. Boost clock is just one BIOS setting. I’ll stick me neck out and say there won’t be two versions of the BIOS. No reason to do that.
All previous generations of strix cards the OC has a different bios to the none OC card despite being the same cards.
Yes the only difference in the bios may well be the max boost clock BUT THAT MEANS IT HAS A DIFFERENT BIOS!
And you are just assuming that both bioses give the same max wattage for the card. They perhaps dont as people who buy the less boosted none oc wont need as much juice as the OC card.
Did simple to do and helps differentiate between versions and justifies the extra $20-$30 for the OC card. Not every buyer will be conformable flashing a bios on a £1700 card so they will spring the extra money for the OC card.
Semantics now. But if I go into my mobo BIOS and change a setting that does not make it a different BIOS. The BIOS is the firmware for the card, changing a setting does not make it a different version. I think the problem os you are trying to justify the small extra spend on the card when there is no justification. Not in the way you want.
There will be no need to flash the BIOS. It will be the same bar one setting. As it always is between SKUs of the same GPU/AIB combination.
Awesome, just hope small in this instance translates to 26 TUF OC’s![]()
