Its a tricky issue is the problems are not just one thing. People even with the new firmware report flickering in certain aspects of a game, i.e. the menu screens, but not during game play. This has been a phenomenon since 144-165Hz and beyond screens game onto the market from all manufacturers. So there exists some glitch between a games settings, the GPU and a screen. But, only with some set ups. I have seen over the years people simply reinstalling the game after upgrading to 144Hz and that resolved the issue. All screens shipping will have the latest firmware as standard.
Here you go. https://forums.overclockers.co.uk/s...ate+firmware&t=post&o=date&c[thread]=18888669Good Day To All!
I also have problems with the monitor flickering at 144 Hz. The firmware is not updated. Video card Vega 56.
The consolation is that the Vega 56 is not able to produce 144 Hz in most modern games.
Q: is it possible to update the monitor software yourself?
I sourced mine from elsewhere after contacting Iiyama directly and asked who had a recent shipment with the correct firmware.
Arrived, all plugged in and working with the latest firmware. I must say this monitor is spot on. I'm not using for gaming however I wanted an Ultrawide for single monitor work setup. This ticks the boxes for me.
)Thanks for posting this!The best review I could find so far. It's in Dutch I believe, so I recommend using google translate.
https://nl.hardware.info/artikel/9987/iiyama-g-master-gb3466wqsu-b1-red-eagle-review-va-of-ips
https://translate.google.com/transl...ed-eagle-review-va-of-ips&prev=search&pto=aue
I hope it hasn't been posted here yet.
Update 7/29, 6:30 PM : Problems with Freesync
After publishing the review of the GB3466WQSU-B1, a number of users reported because their screen is showing problems. As can be read in the comments below this article, those users experience that the screen flickers when Freesync is used at 144 Hz, about which complaints can also be read elsewhere on the internet.
Our current monitor testing procedure consists largely of synthetic test patterns and measurements. To our regret, we did not notice the problem during the GB3466WQSU-B1 test. Based on the feedback, we revisited the screen in a practical situation. It indeed appears that our sample also shows the problems mentioned. At 144 Hz with adaptive sync switched on, or at 144 Hz with the 'Direct Drive' setting switched on, a short white flicker is seen several times per minute. The effect occurs in conjunction with both the Nvidia video card and the AMD video card in our test system. When adaptive sync is turned off in the GB3466WQSU-B1 menu, there is no flickering, even at 144 Hz.
We naturally presented our new findings to Iiyama, but the manufacturer was not yet able to respond in the short term. In order to be able to identify problems with the use of adaptive sync more quickly in the future, we will update our test procedure.
For those wondering whether the problem also occurs on Iiyama's recently tested sister model, the GB3461WQSU-B1, we have good news. We also reviewed our sample of this screen and did not experience any flickering with either video cards in our test system when turning on Freesync. The setting 'Direct Drive Mode' also does not cause image errors on the GB3461WQSU-B1.
Update 11-8, 11:00 : Freesync problem fixed with firmware update
After our email, Iiyama went to work very energetically to find a fix for the problem. The manufacturer has also raised the bell at stores that sold the GB3466WQSU-B1 to stop sales, so that incorrect monitors were no longer supplied. A firmware update was already available a few days after our message. Last week we received a new sample containing the new firmware. Indeed, the flickering when using Freesync was now fixed in combination with the AMD RX480 in our test system, both at 144 Hz and at lower refresh rates within the panel 's Freesync range .
For the sake of completeness, we also tested the screen in combination with the Nvidia video card in our test system, a GTX 1070. The new sample did show flickering when G-sync was switched on, although this is a dark instead of a light 'blink' , which previously affected the monitor. However, the Iiyama GB3466WQSU-B1 is not officially G-sync Compatible certified and only has the AMD Freesync Premium Pro logo. If you want to be assured of a flawless display when using G-sync, it is always wise to consider a screen that does have that certification. It is also possible that G-sync will work well in combination with other video cards or driver versions.
Iiyama announces that it is currently working to provide all stocks of the GB3466WQSU-B1 with the new firmware. The updated screens will return to the stores from this week, so that monitors that you buy from then on will in principle be equipped with the new firmware. However, if you are concerned that your new screen has been updated, you can check whether the monitor has the new firmware by looking at the screen that is shown when you turn it on. In this post in the topic about the GB3466WQSU-B1 at our neighbors from Tweakers, you can see exactly what to look out for.
Have you previously bought a GB3466WQSU-B1 that still has the old firmware? Unfortunately, it is not possible for end users to update the firmware, because you need an extra piece of hardware. Iiyama promises that consumers who have a screen with the old firmware can get an on-site update free of charge through the service program.
That’s my question too,and from what I read,as long as GPU is powerful enough to maintain same frame rate as monitors refresh rate,gsync and freesync won’t be that important.The real question is, will it matter if you have a 3070/3080? Do you even need gsync?
I know 3080 can do it,not sure about 3070 though.
