I bought one of these monitors this week, came with new firmware installed but I'm still getting flickering at 144hz in every configuration (FreeSync/GSync on/off). Awaiting delivery of a new DP1.4 cable today to check that aspect before i get onto the Iiyama support line. Anyone else been having flickering issues post-new firmware? I'm not talking the odd bit of flickering here or there either, it's more like once every 2 seconds on the windows log-in page and every 10-20 seconds on the desktop, games, other apps. Absolutely fine at 100Hz. I'm running a GTX 1060 6GB. Tried uninstalling and reinstalling drivers and GPU firmware update too.
[TLDR: Got a new monitor with new firmware, still had flickering, fixed it, if you are in the same situation check 3 these things:
1) Get new firmware for the monitor.
2) If it is 10 series or earlier get new firmware for you GPU.
3) Buy a new DP1.4 spec cable, or more precisely, an HBR3 cable according to a quick bit of research (I think just searching for DP1.4 cable capable of 4K @144hz will get you what you want).]
I thought I should follow up my post in case it helps someone else. I believe I have fixed my flickering issue with the steps below whilst keeping FreeSync and GSync (although see note 2 below) on all the time with my GTX 1060 6GB.
I received my monitor earlier this week with the latest firmware already installed. When I plugged it in it with the provided cables it defaulted to 1080p vertical and 60hz (from memory, it may not have been 1080p but it was definitely 60hz). I upped this to 1440p and 144hz and immediately got loads of flickering combined with a static noise (I think from the speakers? But could have been coming from anywhere). I tried all sorts of Freesync, Gsync and other OSD options with no fix, but there was never an issue at 60hz or 100hz and I even had it running absolutely fine at a custom resolution with 120hz refresh rate, then 130hz, then 134hz – but no more. I also did the following:
1) Updated the firmware of my GPU with Nvidia’s tool for DP1.3/DP1.4 capability (it looks like this needs to be done for all 10 series and Pascal cards or earlier):
https://www.nvidia.com/en-us/drivers/nv-uefi-update-x64/
2) Updated windows, I’m running Windows 10 Version 1903 OS build 18362.1082.
3) Uninstalled my Graphics Card drivers through device manager > display adapter > GTX 1060 > uninstall device, then reinstalled latest drivers from Nvidia (456.71 for me).
This didn’t solve the issue, so I ordered a new cable – specifically supporting DP 1.4 (or HBR3, whatever, hopefully you know what I mean). This said it was “8K ready”, “4K @ 144hz ready” and capable of 32.4Gbps bandwidth, weirdly this doesn’t seem to match any of the specs on wiki but nonetheless…
Now it’s fine @ 1440p and 144hz.
I’m no electrical engineer so I’m not going to point the finger, but it seems suspicious that a DP1.4 cable was the last step in resolving the issue and previously I couldn’t get the refresh rate past 134hz at 1440p – isn’t this about the theoretical limit for DP1.2 bandwidth (or more accurately I believe HBR2?) on an ultrawide 1440p resolution assuming a bit of compression in the signal? (Wikipedia says 17.28 Gbit/s my calcs say 134hz is 19.91 Gbit/s.)
It feels like there is some quality issue with the cable provided. Otherwise it makes no sense to me why a manufacturer would provide a DP1.2 cable that isn’t capable, but then why do they provide HDMI ports/cables which aren’t either?
Some observations and questions to other owners having issues:
1) Is your card a 10 series or earlier? Make sure you also install the Nvidia firmware upgrade.
2) With the manufacturer provided cable I had the option of Freesync in the OSD and GSync in the Nvidia control panel all the time (as far as I am aware), with my new cable, I could enable FreeSync in the OSD but the option to turn on GSync was gone at first, then appeared again when I changed something else in the Nvidia control panel (I just changed the power setting from “max power” to “optimal”, I don’t think it’s related). I’ve never had to use Nvidia control panel much but having delved into it now it seems glitchy/laggy as anything. Nonetheless, I can confirm GSync compatibility is also on now but seems to come and go, if it is ever properly certified hopefully that’ll be resolved.
3) When I first used my new cable I had the option in the OSD for DP1.2 or DP1.4 mode but around the same time GSync popped up again in the Nvidia control panel it became greyed out. A similar thing happened with the original cable, It was there at first, then never came back… odd. (Oh well I’m still at 1440p 144hz).
4) I went back to the old cable just to test it again, and straight away I was able to recreate the flickering at anything above 134hz.
5) Another strange note, at 134hz on the old cable and at 134hz on the new cable I get really intense flickering when I use the OSD (But not at 144hz when I use the new cable). I’m going to keep it at 144hz and It’s the OSD so I don’t care, but it’s weird.
6) I obviously can’t test pushing games at >144fps with a GTX1060 at this res to see if there is any issue there, but I also saw no flickering in menus at >200fps and playing GRID 2, RimWorld, Total War: Troy and Overwatch for an hour or so has been fine with 0 issues.
It was kind of interesting investigating this, hopefully this long post is useful to someone who may be able to provide a more scientifically accurate answer sometime or come up with other more exact ideas for fixes, but this worked for me. Now I’m going to go play some games and hope this holds true forever.
