- 1 Jul 2016
Have any of you found the default fans barely push any air? They're very quiet, but can't feel much airflow even at max rpm.
its literally sat ontop of the ram, all screws in however. So a heads up for anyone dont buy snazzy tall rgb ram with an aio!![]()
What sort of temps are you getting?
Went for the same aio setup in a NZXt h710 but I'm finding the closed off design not doing great for temps, looking at a potential move to this case.
Would the Liquid Freezer II 240 fit top mounted? (it is around 63 mm thick)
I wanted the AIO on the front as intake, and top/rear as exhaust, but I'm worried about negative pressure.
Any advice on how to setup the airflow with this AIO and the 3 stock fans?
it is built like a tank though, that's how it feelsIs there another 15mm between the video card and the arctic cooler? I'm planning on a similar build but I don't have a 3080 yet, I'm on queue for EVGA cards and some of them are up to 300 mm compared to the 285 of the NVIDIA FE.. so wanted to make sure..... Thanks
Yes there is 50mm gap between the end of that card and the radiator fins. I just measured it for you![]()
Thank you, really appreciate it.
I was also between the Lancool and the 500DX, but like you mentioned, can't find the Lancool in stock, so this one looks like a winner.
I did some research and the Arctic Freezer 280 is an excellent cooler and seeing your build convinced me that I'm on the right track.
. Normally I don't hear the GPU as the fans are <50% with temps in the 60Cs. Some games push the card and I see GPU temps of 72C max (77C without the undervolt) and my 3700x bobs around the 50C mark.
The FE 3080 not big at all, think it smaller then most AIB gpu'sHere is mine with the 3080 just housed.
The FE 3080 is not that big in real lifeit is built like a tank though, that's how it feels
It the FE 3090 that Big
so the h100i fits, barely! My god its tight to the ram ha
Remember the arctic rad is a bit thicker than some other AIO coolers, so better measuring what space you haveHas anyone top mounted an Arctic freezer 2 on it ? Like the 240 ?
