Anyone struggling with flickering I've found adjusting response rate down helps a lot.
GTX 1080
This is what’s wrong with products in this sector, quality control and delivering a fully functional, “fit for purpose”, product, performing as it’s sold and advertised to do so, is not a given, or something you can expect and count on, it’s a luxury and a bit of blind luck...
Imagine buying a car, the stereo doesn’t work, but the car still drives ok, and gets you from A to B, so the dealer just tells you to forget about the radio, it was just a extra you can live without lol..
We have retailers peddling this overpriced, underperforming garbage to us, and telling us to “reduce performance” and “do not use the product as it’s designed to be used” in order to bypass product faults.
Disgusting, both manufacturer and seller should be ashamed.
