yep, nothing but amd v nvidea until thenthis thread is 1 page of actual information and 142 of bickeringwhen are we expecting actual news? The 28th?
The 5700 XT was targeted at 1440p gaming. The 1080 Ti, RTX 2080 and RTX 2080 Ti still provided higher performance at this resolution.
We know AMD is targeting Navi 2x GPUs at 4k resolution. As with the 5700 XT, I don't think they are offering the most powerful GPU, at the targetted resolution.
Based on the perf. advantage NV had vs RDNA gen 1, it seems likely that 1-2 GPUs will still have an advantage, such as the RTX 3080 and RTX 3090.
I mainly game at 1440p 165hz and putting a budget down of £550 max which I firmly believe AMD will cover with hopefully a cracking card.
I once had a pre-order for a 3080 on the 17th, ordered 14:18pm and queue position was ridiculous. Cancelled my order over a week ago and have decided to wait for AMD announcements and 3070 availability.
According to Moore's Law Is Dead, there should be an absurd amount of stock for the 3070... we'll see on that? After this fiasco, I'll wait and see what's on offer from both camps at the end of this month.
The 3070 supply would make sense of there have been yield issues or problems hitting the clocks in the higher SKUs. Easier to produce 3070s out of the same silicon.
Someone pointed out to me that the cards use different memory and off the GA104 so not on the same as the 3080's.
I can't say for sure it is what they are doing at Samsung but one way products like this are often fabricated to reduce wastage is to put multiple products of all sizes on the same wafer (I'm not sure how advanced Samsung's facilities are in this respect) - typically under this kind of scenario you'd be creating something like ~7 GA104 cores for every 1 GA102. So in theory at least as far as the cores go they should be much higher volume than the higher end parts. (Obviously you then have things like what functional cores can actually do frequency wise, etc.).
EDIT: Though the AMD 7nm wafers I've seen so far have all been end to end the same product which surprised me a bit.
I'm not sure what the situation is stock wise for GDDR6 either.
Correct but I reckon there will be 100,000s of 3070 available.
Nvidia will be:
"cant buy a 3080 or 3090 anywhere don;t worry we have plenty of 3070s and they are only £700 - a bargain!"
Doesn't sound like an amazing play if AMD have their supposed better performance cards out in quantity.
Where was my invite?
Although I have been talking a lot of sense in there which is not at all like me.Interesting news on the XSX
#### cross breeders...
