only by a little bit - from what I've seen with RTX turning RT on at 4k requires an extra 500-1000mb of vram
Depends a bit on the implementation - IIRC Quake 2 RTX grabs an additional 2.5GB allocation for screen buffers alone at 4K.
That's a lotDepends a bit on the implementation - IIRC Quake 2 RTX grabs an additional 2.5GB allocation for screen buffers alone at 4K.
Well, RT increases VRAM usage, so even that scenario would cause VRAM to be a factor earlier on.
Navi 21 at only 2.1Ghz was looking shakey
Navi 22 at 2.4Ghz is looking promising
Allegedly![]()
255w is tough to swallow.. humbug should be out with his calculators any time now![]()
The firmware stuff (assuming it is real) had 250watt and 230watt options but 2.4GHz at 255watt on any larger core with RTX 3080/90 performance would need quite some engineering.
You get my point tho?
Its 70% more power than the Series X GPU.
What would that be in relation to Rx 5700 xt?
0% more power, 120% higher performance?
On the Chiphell's graph it's 132%![]()
https://www.chiphell.com/thread-2264233-1-1.html
Let's hope these figures are not out of thin air.
How? the 3080 is 350w!!!255w is tough to swallow.. humbug should be out with his calculators any time now![]()
