Great, more limited edition cards (6900xt), just what we need. Chapeau AMD, chapeauAs bad as Nvidia and the non existent founders models.
Who would have thought spending your hard earned could be so hard![]()
Rumors of early to mid November, nothing concrete, im guessing a week after Cpus tho, so around the 12thWhen is the actual launch date?
If the 6800xt is a 72cu card competing with a 3080. How does 8 more CUs get you 3090 performance at 4k?? And how are they able to bump the gpu clock higher with more CUs??
Its called engineering with innovation and design goals.
Seems amd going for beating the 3090 and could even have a watercooled edition this time.
They can simply go higher with clock speed a bit above the efficiency spot.
Like Nvidia had to do with a broken samsung 8nm node that crashed them...when people gamed.
AMD has no competition this time either from intel nor nvidia.
Its game over for them.
Disruptive the market at 4k indeed and all the rest to
Due to all these cards are likely even the 40cu is either faster or match the 3070 and they can add 2 more cards between then in the money slot that counts for the majority of buyers.
Not the few that buys $800-1500 cards.
How much does nvidia pay you sir?!What? if we assume what they showed off was the 72/4608 card (and it would take a minimum of such spec at ~2GHz to pull off those numbers and I wouldn't put it past needing the 80 CU spec) then the 80 CU card is not a 3090 beater. And you definitely aren't matching the 3070 with a 40 CU part.
How does that work when we have seen AMDs own slides of a Big Navi card trading blows with a 3080???Going by shader counts big navi may end up competing with the 3070. Its not known for amd cards to match nvidias shader for shader.
Hopefully and have something that beats the 3080 in everything. That means price wars!!!
Just kidding![]()
It is an Nvidia Killer man, read the title!Am just being realistic - people seem to be taking AMD's 50% perf/watt up lift as a literal +50% performance - it doesn't work like that.
Because amds slides also showed the 5700xt trade blows with the 2080 but when proper reviews came out with larger variety of games it showed the 5700xt loosing out to a 2070 a lot of times.
Consistent performance is not something amd is known for.... Well consistantly low it comes up to
Thats even more mysterious than the performance.When is the actual launch date?
And even if you go conservative with what the actual performance increase would be, a 40 CU card at 225W would edge out a 2080 Ti, and therefore would be right there with the 3070. So yes, it is entirely possible AMD can take on the 3070 with only 40 CUs.Am just being realistic - people seem to be taking AMD's 50% perf/watt up lift as a literal +50% performance - it doesn't work like that.
Well that's just completely wrong. Did you just make that up?Because amds slides also showed the 5700xt trade blows with the 2080...
